![]() Drives: 2016 2SS blue velvet w/blk stripes Join Date: Sep 2017
Well i guess BG DOT4 is not gonna cut it on a track day. Seems MOTUL 600 is a popular choice and not too hydroscopic. I only track a few times a year so i want a balance between high temp fluid and longevity between flushing.
Do i need to change the current, week old fluid right away now that i pushed it past the boiling point already? Will it be safe to wait till next track day?
Current mods. Rotofab CAI, Speed Engineering Long Tube Headers and plug wires w custom tune. Shock tower brace, ground effects, OEM brake air ducts and splash gaurd delete, 275/315 tires on 10 and 11 inch MRR wheels.
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
If you boiled it and your pedal went to the floor it is done. You can bleed it, to get fresh fluid in the caliper, but the fluid itself does not sound like it is up to the task and will just boil again.
At track speeds, thats not the area where I want to save money/fluid or risk safety. I have been using Motul 600 for many years and it has been good. Bleeding brakes is part of the track day experience unfortunately.
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
#3 | |
2020 Shadow Gray 2SS
If it went "to the floor", it is DONE... Get it out of there and get some really good fluid in there...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Castrol SRF, Brembo HTC64T, Endless RF650 ot Torque 700 are the only choices of high temp, high quality track ready brake fluids. You will have to flush ALL the old fluid out. And do the ABS bleed procedure too. High quality brake fluid is the cheapest insurance you will ever buy for a track day. There are many characteristics that define brake fluids and the above four choices will have what it needs for track day safety and fun. Castrol SRF is usually the go-to for a good balance of cost and quality. The others are more expensive but have some different characteristics, for which does not make the SRF a lesser quality item. Good reads: https://thebuildjournal.com/tech-gui...view-analysis/ https://thebuildjournal.com/tech-gui...parison-guide/ You mentioned your pedal went to the floor. What car, pad, cooling setup do you have? Looks like a non- 1LE SS. Did you install the large brake cooling deflectors that came in the trunk of the car?
"KEEP THE FAITH"-Fbodfather |
![]() Drives: 2021 Camaro 1SS 1LE Join Date: Aug 2014
I agree Castrol SRF is the most popular, and it's what I use. But, I've never had a lick of issues with Motul 600.
As for the need to bleed, I will say this: I've had the pedal go soft with SRF, but it came back after cooldown. From what I understand, that means the fluid was at the brink and got hot enough to be "compressible," but not boil. Allegedly, if it boils, the pedal doesn't come back without bleeding it. I bled it to be safe, anyway. I've bled with new fluid multiple times since (track dedicated car), and I've never done the ABS procedure on it. |
#6 | |
Castrol SRF ftw I boiled Motul 600, and never went back.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
#7 |
![]() Drives: 2023 Camaro SS1LE Join Date: Oct 2023
Agree with flushing that fluid out of there and replacing with something better. I also use Castrol SRF and have gotten the brakes really hot on track and no issues with fluid boiling. I flush the SRF once per year in the off season and bleed the calipers each time I change brake pads.
2023 Camaro SS1LE
1989 Trans am GTA |
#8 |
![]() Drives: Cadillac ATS-V Join Date: Feb 2023
Some people prefer the pedal feel of Endless 650...but SRF is the easy button for all-season longevity AND let's be honest, as far as car fluids go its not THAT expensive.
2018 Cadillac ATS-V Sedan
NCM*Putnam Park*Mid-Ohio*Gingerman*Road Atlanta*Barber*Pitt Race*VIR |
#9 | |
#10 |
Great info guys now i know what fluid to use for the next track day. Flushing my calipers now untill i upgrade. Thanks for all the feedback!!
#11 |
What track were you on, sounds intense your a good driver!!!
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i used motul 660 never had any issues
#13 |
![]() Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
Castrol SRF ftw. I change every 2 years, and do 8-10 track days on a flush. I also drive my car 5-6 months a year as a daily
#14 |
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
Yep. Castrol SRF. No need to even bleed it during a season of 7 track days. I just flush it once per year, but have heard of others going a bit longer.
Can't quite say the same for Motul 600 that my Mustang friend insists on using. The fluid goes from clear to dark after 2 track days and he's replacing it at least once or twice a season. He hasn't any fluid boiling moments, but that might be because he replaces it frequently (and is ultimately spending more $ than if he'd use SRF). |
| Tags |
| boiling point, brake fluid, track day |
