Old 09-24-2024, 02:27 PM   #15
Saberscar223
Saberscar223's Avatar
Drives: 2023 Riverside Blue 2SS
Originally Posted by ctrlz View Post
The converter will not present any kind of restriction at idle.
As jlaudio mentions, idle is going to be an open loop mode, and the car will use tables to match fuel and spark timing to density (from MAF data) and speed (engine rpm). Coolant temp is also a factor.
You need to know what your A/F is at idle. Sounds like it might be overly rich. This needs to be tuned to get it right, particularly with your mods.
aplogies i meant at parking lot/heavy traffic speeds
Saberscar223 is offline   Reply With Quote
Old 09-24-2024, 03:41 PM   #16
ctrlz
You might want to try posting your problem in the tuning sub-forum.
I don't think your tuner finished the job. It does not sound like you installed "wild" parts that should not work with the car.
Old 09-24-2024, 04:41 PM   #17
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Yeah its super jumpy at idle, mainly because I'm still running the stock converter wondering if upgrading that would fix the issue.
A looser converter would lessen you feeling that jumpiness but wouldn't really fix it. The higher your idle rpm is the closer you'll get to the converters stall speed and you may feel more it. I've tuned multiple cam'ed setups on stock converters and it can be smoothed out. Idle and off idle can be a pain on a cammed gen v's though. Getting the actual and virtual torque inline can take some time.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 09-26-2024, 10:35 AM   #18
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
I don't have the issue on my SS. Which is 3 years older than yours. I also don't have the DA you do most of the time.
But without reading the rest of the thread, my gut tells me thermostat or the opening of the cooling system at certain temps in the tune.
