Old 08-05-2024, 10:44 PM   #15
ICTsccaCamaro
Drives: 2018 ZL1 1LE
I badly need to do this myself also, was planning on the Kateck pump and doing the C5R chain and an aftermarket tensioner.
@Katech_Mike What is your thoughts on just using an OEM LT4 chain and tensioner vs. the C5R chain and a billet aftermarket tensioner?
ICTsccaCamaro is offline   Reply With Quote
Old 08-06-2024, 08:53 AM   #16
Katech_Mike
Drives: 2015 Camaro ZL1
For road course use I would highly recommend the LME solid chain guide.
The OEM LT chain is upgraded versus the LS chain so the gap between OEM and C5-R isn't as large.
Katech_Mike is offline   Reply With Quote
Old 08-18-2024, 07:11 PM   #17
ICTsccaCamaro
Awesome so your oil pump, stock LT4 chain and LME guide should be a good package to relieve my stress on track and not have me watching my oil pressure every lap
Old 08-20-2024, 07:46 PM   #18
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
I did the chain and damper with the oil pump. While your there I think it’s worth the few extra hundred.
pauly1119 is offline   Reply With Quote
Old 08-21-2024, 05:41 PM   #19
zain
zain's Avatar
Drives: ZL1
Originally Posted by OneLapWonder View Post
Subject: 2018 Camaro ZL1 1LE
Build Date: 09/17
Mileage: 21095 mi
Oil used: Mobil 1 ESP X3 0W-40 or Mobil 1 15W-50
Oil pressure: 40 psi (cold idle), 30 psi (warm idle), 40+ psi (cruise)
Decided to pre-emptively replace the oil pump since the car and motor are too expensive to be considered throwaways, and I rather like the car for track use.
Dis-assembly starts the next weekend.
Parts Purchased:
(qty 1) Katech Racing Oil Pump $550.62
(qty 1) GM GENUINE 12638433 Oil Pump Gasket $4.57
(qty 1) GM GENUINE 12686431 Oil Pump Control Valve / Solenoid $12.55
(qty 1) GM GENUINE 12634614 Front Crankshaft Engine Oil Seal $9.49
(qty 1) GM GENUINE 12666993 Oil Pan Gasket $5.50
(qty 1) GM GENUINE 12638820 Oil Level Sensor Gasket / O-Ring $10.30
(qty 1) GM GENUINE 24504031 Oil Dipstick / Tube Seal $9.45
(qty 1) GM GENUINE 12646872 Positive Crankcase Ventilation (PCV) Valve $45.89
(qty 1) ACDELCO 12646386 Timing Chain $57.75
(qty 1) GM GENUINE 12630107 Timing Chain Tensioner $36.79
(qty 2) GM GENUINE 12657430 Water Pump Gasket $3.39
(qty 1) GM GENUINE 12663624 Idler Pulley $63.79
(qty 1) GM GENUINE 12665845 Idler Pulley $55.99
(qty 1) GM GENUINE 12678295 Idler Pulley $51.79
(qty 1) GM GENUINE 12678515 Idler Pulley $42.79
(qty 1) GM GENUINE 12686229 Belt Tensioner $54.79
(qty 1) GM GENUINE 11547372 Harmonic Balancer Bolt $15.41
(qty 1) GM GENUINE 12639086 Throttle Body Gasket $6.80
(qty 1) GM GENUINE 12668317 V-Ribbed Serpentine Belt $69.94
(qty 1) ACDELCO 12643218 Belt $17.67
(qty 1) ACDELCO 12685983 Belt $14.50
(qty 1) ACDELCO PF64 Oil Filter $3.49
(qty 1) DORMAN 097119 Oil Drain Plug Gasket $1.07
(qty 2) ACDelco GM Original Equipment Dex-Cool 50/50 Pre-Mix Engine Coolant - 1 gal P/N 10-5027 $15.64
Total: $550.62 + $628.38 = $1179, then add the cost of 10-11 qts of engine oil
Parts Sources:
rockauto.com
gmpartsdirect.com
thanks for sharing!, I might go for the same. Please keep posting for updates
zain is offline   Reply With Quote
Old 08-21-2024, 07:57 PM   #20
HypeBlueZL1
Drives: Chevrolet Camaro ZL1
We're all rooting for you OneLap. I intend to keep my car forever and can imagine I may have to do this job one day.
HypeBlueZL1 is offline   Reply With Quote
Old 08-23-2024, 03:25 PM   #21
NicKey
NicKey's Avatar
Drives: Nickey Super Camaro
Do not forget that you will need some engine gasket sealer as well.
NicKey is offline   Reply With Quote
Old 08-25-2024, 09:25 AM   #22
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
How is the project going?
george is offline   Reply With Quote
