![]() Drives: 2008 Audi RS4 Join Date: Jan 2020
2018 ZL1 Oil Pump Replacement
Subject: 2018 Camaro ZL1 1LE
Build Date: 09/17 Mileage: 21095 mi Oil used: Mobil 1 ESP X3 0W-40 or Mobil 1 15W-50 Oil pressure: 40 psi (cold idle), 30 psi (warm idle), 40+ psi (cruise) Decided to pre-emptively replace the oil pump since the car and motor are too expensive to be considered throwaways, and I rather like the car for track use. Dis-assembly starts the next weekend. Parts Purchased: (qty 1) Katech Racing Oil Pump $550.62 (qty 1) GM GENUINE 12638433 Oil Pump Gasket $4.57 (qty 1) GM GENUINE 12686431 Oil Pump Control Valve / Solenoid $12.55 (qty 1) GM GENUINE 12634614 Front Crankshaft Engine Oil Seal $9.49 (qty 1) GM GENUINE 12666993 Oil Pan Gasket $5.50 (qty 1) GM GENUINE 12638820 Oil Level Sensor Gasket / O-Ring $10.30 (qty 1) GM GENUINE 24504031 Oil Dipstick / Tube Seal $9.45 (qty 1) GM GENUINE 12646872 Positive Crankcase Ventilation (PCV) Valve $45.89 (qty 1) ACDELCO 12646386 Timing Chain $57.75 (qty 1) GM GENUINE 12630107 Timing Chain Tensioner $36.79 (qty 2) GM GENUINE 12657430 Water Pump Gasket $3.39 (qty 1) GM GENUINE 12663624 Idler Pulley $63.79 (qty 1) GM GENUINE 12665845 Idler Pulley $55.99 (qty 1) GM GENUINE 12678295 Idler Pulley $51.79 (qty 1) GM GENUINE 12678515 Idler Pulley $42.79 (qty 1) GM GENUINE 12686229 Belt Tensioner $54.79 (qty 1) GM GENUINE 11547372 Harmonic Balancer Bolt $15.41 (qty 1) GM GENUINE 12639086 Throttle Body Gasket $6.80 (qty 1) GM GENUINE 12668317 V-Ribbed Serpentine Belt $69.94 (qty 1) ACDELCO 12643218 Belt $17.67 (qty 1) ACDELCO 12685983 Belt $14.50 (qty 1) ACDELCO PF64 Oil Filter $3.49 (qty 1) DORMAN 097119 Oil Drain Plug Gasket $1.07 (qty 2) ACDelco GM Original Equipment Dex-Cool 50/50 Pre-Mix Engine Coolant - 1 gal P/N 10-5027 $15.64 Total: $550.62 + $628.38 = $1179, then add the cost of 10-11 qts of engine oil Parts Sources: rockauto.com gmpartsdirect.com
2012 Lexus CT200h Premium Navi
2008 Audi RS4 2004 Audi S4 2018 Chebby Camaro ZLE HMB Last edited by OneLapWonder; 08-03-2024 at 07:36 PM. |
Who Needs to KNOW?
Add to title: DYI Parts w Required KATECH
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
Please keep us posted. Are you doing this yourself? If not, who is doing the work?
![]() Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
subd for parts list
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
#5 | |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
Add to the list...
USE REAL OIL... not the marketing hype Mobil1 if you really believe... Quote:
#6 | |
It looks like the components that need to be removed are: Front crossmember Oil pan Belts Crankshaft Damper Water pump Front main cover Oil pump
2008 Audi RS4 2004 Audi S4 2018 Chebby Camaro ZLE HMB |
#7 |
Recommendations based on your experience?
#8 | |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
There have been many, many ZL1/ZL1 1LEs (to include mine) that have been throughly tracked on a road course and haven't had issues with the stock oil. Same can be said and about all the other Camaro's too. There has also been a 2017 ZL1 that has been taken to over 210k miles with this "inferior" oil and had zero issue and only had the basic maintenance done when required. |
#9 |
![]() Drives: 2022 ZL1 1LE Join Date: Sep 2015
ZLElvira,
Please do tell us which is the “real oil” we should be using. JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!! 2021 F-250 FX4 2023 Hyundai SF Calligraphy |
#10 |
Ordered July 26 (Fri noon-ish)
Delivered July 30 (Tues) ![]() ![]()
#11 |
ZL1 Driver
I’m in PA as well. If it works out, would you be willing to do mine for a fee?
#12 |
Let’s chat afterwards. I’m usually open to helping another but I’m also fairly firm on pre-requisites and constraints to avoid either party ending up worse off than where started.
#13 |
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
#14 |
ZL1 Driver
I get it. Let me know how it goes. I hope it goes well.
