Old 06-20-2024, 06:55 PM   #15
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Don't overfill your oil is pretty effective also.
wakespeak is offline   Reply With Quote
Old 06-21-2024, 06:43 AM   #16
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Here's OP< and here's the Topic way over HERE >>>>>>>>>>>>>>>
Old 06-30-2024, 12:10 PM   #17
Nallek
Drives: 2018 Camaro ZL1
Originally Posted by groupleader View Post
Hey guys, considering purchasing a used 2023 ZL 1. I have read a couple articles from other social media, concerning oil accumulation under the lid of the supercharger after about 6 thousand miles on the odometer. Was wondering if this is something I need to be concerned about. Was planning on installing an oil separator, catch can, but it looks like you need to remove the top cover of the SC, to access the PVC valve. I'm a little leery of tearing apart the top end of the engine considering the car still has 28 months of factory warranty on it, really don't want to jeopardize my warranty by taking apart the blower. So, was wondering what other options I might have concerning an oil catch can. The car
only has 1420 miles on it, but really don't want any oil leaks at 6 or 7 thousand miles either. Any suggestions would be greatly appreciated thanks.
You'll need to take the bolts out of the supercharger completely, tilt it up and rest it on something sturdy to be able to access the PCV valve. Those bolts are torque to yield (you can reuse the lid bolts), so you'll have to replace them and torque to spec, but I did mine in my driveway in a day without issue. I, personally, would recommend an oil catch can for ANY direct injection application.
Nallek is offline   Reply With Quote
Old 06-30-2024, 12:14 PM   #18
Nallek
It's not so much the oil you see under the lid, that same oil has also already coated your supercharger bricks making their cooling less efficient, and oil that already passed on to the top of your valves. It's true on a stock ZL1, a catch can matters less, but once you start modifying one of these cars to produce more boost, a catch can becomes a much better investment. Having a catch can with a vent is even more important to reduce crankcase pressure. There's literally no downside to using a catch can other than warranty concerns which depends on your dealer.
This ^^. So much this. Its the oil that cakes on the tops of the valves that you need to avoid. Because it is direct injected as opposed to port injected, the gas doesn't help clean off the valves each cycle, so it just continues to build on the valves.
Old 06-30-2024, 03:56 PM   #19
triggerjerk
Drives: 2023 Camaro ZL1
Has anyone documented carbon build up on intake valves of a stock ZL1 LT4?
I would assume the risk is very low especially with use of a dexos or mobil 1 oil that meets ilsac gf-6.
These were interesting to read:
https://www.corvetteforum.com/forums...jection-2.html
see post 233 here:
https://www.stingrayforums.com/threa....12271/page-12
triggerjerk is offline   Reply With Quote
Old 07-01-2024, 05:45 AM   #20
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Stock engines are fine. GM sorted out the GDI carbon buildup issues in the Gen5 LT engines in MY2015. Has since been debated and documented multiple times on these forums, with pictures similar to the LT4 in the 2nd link (i.e. not an issue). Catch cans are not necessary.
Catch cans are recommended for modded/tuned cars.
Old 07-03-2024, 07:26 AM   #21
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool Easy fix!!
It is really just the oil vapor being pulled into the SC inlet from the valve covers. I added two $30 Air/Oil separators I bought on Amazon, made two aluminum brackets and spliced them into each plastic line using the provided hoses in the kit with epoxy sealed heat shrink between the hoses. In six track days and 10,000 miles... I have zero oil in my SC bricks!! I didn't go buy some high-dollar Mighty-something catch can and remove any of the factory systems to clean my SC's airflow. Understand... if there is oil in the SC under the lid... it has ALREADY gone past the rotors and they are covered too.
While removing the lid, you can take out the STEEL NOISE ABATEMENT PLATE and drop your Manifold Air Temps while also increasing the Supercharger Whine noise we all love! Another example of how the Engineers were told by tree-huggers at GM that SC Noise is BAD!!
Removing the lid, cleaning and taking out the steel plate is a 15-minute procedure. You will thank me later!!
https://www.youtube.com/shorts/cU604JnOhGI
Patriot Motorsports USA is offline   Reply With Quote
Old 07-03-2024, 07:28 AM   #22
Cool This is how you do it!!
This is how you remove the supercharger lid and steel plate at the track to see immediate performance gains!
Old 07-03-2024, 08:20 AM   #23
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Other than the louder blower whine, I'm very skeptical with any other claim about removing the plate in the lid.
GM Gen V Calibrator
Old 07-03-2024, 08:35 AM   #24
Cool
Exactly why we removed another one while at Road Atlanta to prove back-to-back results and observed the MATs of both air sensors as well as the amount of timing being pulled before and after. The net also showed a laptime reduction due to less timing being pulled on a wide open throttle stretch from turn 7-10a where I reach speeds of 160mph.
In fact... all those shops who sell Billet Lids, not ONE has ever done a comparison of just removing the steel plate in the OEM aluminum lip to the claimed HP gains of a billet lid and no steel noise abatement plate.
Old 07-03-2024, 08:47 AM   #25
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Beast Build
I honestly couldn't tell any difference at all by removing the inside blower plate. But, when I got my DSX lid, it was noticeably much louder of a whine sound, then, when I got my blower Kong X-Port, HOLY CRAP that's a totally different ball game at that point !!!!!
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 07-03-2024, 11:56 AM   #26
Cool
Seat of the pants you really would not notice much unless you are running your car like we are, flat out for 30-40 minutes nonstop!
Here is the session prior to removing the plate from the Orange ZLE M6 running on Hoosier R6 slicks! TURN UP YOUR SPEAKERS!!!
