#15 |
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
I heard that expansion tank is the same as the chevy bolt. Can probably do alot cheaper if that's the case. As for the coolant bleeder, that's a great idea, here is another cheaper option in case anyone is interested.
#16 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
I assume that you are referring to the LSA Conversion kit expansion tank. Yeah you could probably source the parts cheaper than purchasing the kit, but it also comes with a very well done bracket to mount the tank, as well as all the hoses and clamps. If you've got time on your hands (I don't) to locate, purchase and make all the components more power to you.
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
Cordes has a photo on their website installed. Mine is the same except mine is black instead of silver.
https://cordesperformanceracing.com/...xpansion-tank/ |
#18 | |
![]() Drives: Sharkskin Metallic ZL1 Join Date: Mar 2023
I like that tank, in black it looks sharp. |
#19 |
#20 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Dang...I knew I should have mounted my MightMouse to the shock tower!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#21 |
Vengeance Racing mounted my Mighty Mouse directly to the backside of the Rotofab Big Gulp. Not a fan of that honestly but it did make room for the Cordes tank. I suppose the other plus side is that the Mighty Mouse isn't positioned over the headers either.
#22 |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
I can’t see why that wouldn’t work any different than the cordes, as it sits down at the same level.
