Old 04-09-2024, 06:20 AM   #15
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Originally Posted by Hammer-joe View Post
Here's a few pics of my 8.50 cage on my 16 Camaro. Few other things to keep in mind. You will also need a window net and a parachute after 150mph. My cage is a 8.50 cert RPM and is fully welded in. It's not that bad getting in and out once you get use to it. The 16 Camaro has alot less chassis flex then my 18 Camaro with no cage. The rear view mirror and sun visors are useless.
Attachment 1147221
Attachment 1147222
Attachment 1147223
I had the RPM bolt in that we installed in my 16 SS in 2018. Obviously it's safer than no cage and I about had to use it when I pushed the rear seal out on the big end. Oil got under the Hoosier and she was skating around like an icy road here in Missouri, luckily I learned to drive on icy roads and helped me save it from hitting the wall. I did feel safe with the cage in the car even though it was a bolt in. If you saw the pictures of Pray's car after it crashed on the big end a cage may have saved a life. Many are out there running 150 plus with no safety equipment, so do yourself a favor and put a cage in, at least a bolt in. Just my 2 cents worth. By the way your cage looks very well built and safe, hands down one of the nicer ones I've seen in a 6Gen.
Old 04-09-2024, 08:11 AM   #16
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Do you have any pics of your bolt in cage installed? How invasive was it?
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels
1.45 4.01 6.07@120.74 9.28@153.43
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild
jlaudio11 is offline   Reply With Quote
Old 04-10-2024, 08:58 AM   #17
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG
Totally agree with this! I have the bolt in from RPM as well and with a race seat and a 5 point harness I feel very safe going 150MPH in this car!
2019 COPO #32
427 NA
9.38 142MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
