Old 11-01-2023, 08:26 AM   #15
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
The additional cubic inches is the way to go up here as I found out with my Sonny's 740 engine which was much more consistent than the smaller engines I competed against and here it makes sense because as King says I can put a 3-in pulley back on the supercharger. Slow it down to say 17,000 RPMs, shift the motor at say 6500 RPMs and make the same or more power plus having the primary benefit of a built bottom end
The 2650 rotor packs prefers less boost for efficiency as well. After 20 psi they gradually start becoming less efficient.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 11-01-2023, 09:32 AM   #16
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Do you think I've got enough injector and fuel pump for a 416 making 100-110% of current build, XDI 30+, Dsx LS 80#, HPFP delivery duration <93°
yes, on race fuel.
Old 11-01-2023, 02:56 PM   #17
JSH
JSH's Avatar
Drives: '20 ZLE
yes, on race fuel.
I just bought KaTech's 416 sb, oil pump, and cam, the parts are in stock. Happy to hear I don't need LPE's BBFP... yet. Hmm, wondering if it's OK to post the cam specs. Probably.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 11-01-2023, 03:18 PM   #18
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
I think the specs are available on the website
Nimair.ZL1 is offline   Reply With Quote
Old 11-01-2023, 03:38 PM   #19
JSH
JSH's Avatar
Drives: '20 ZLE
Yes. Cam Specs: 233 / 250 @ .050, . 649/ .658 lift, 119+4 LSA, 38% fuel lobe
KaTech says a good tuner can make it a decent street cam.
2020 ZL1LE A10.
Old 11-01-2023, 08:51 PM   #20
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
I have a 235/252 .648 .630 119+5 with factory cubes in the C7Z. Drives good. Stick car
CamOnlyJabroni is offline   Reply With Quote
Old 11-01-2023, 10:21 PM   #21
JSH
JSH's Avatar
Drives: '20 ZLE
Good to know. They describe it as Max Effort.
2020 ZL1LE A10.
Old 11-02-2023, 07:54 AM   #22
KingLT1
KingLT1's Avatar
Did you ask Katech if that cam works with stock stall converter? Pretty sure you would need a larger stall if it was stock cubes but not sure with the 416.
Old 11-02-2023, 08:28 AM   #23
Katech_Mike
Drives: 2015 Camaro ZL1
It will work with a stock converter even with stock cubes.
It will be right up against the converter so you can experience some pulsing at idle in gear.
The larger cube engine will swallow up the cam as bit as well.
Katech_Mike is offline   Reply With Quote
Old 11-02-2023, 08:54 AM   #24
JSH
JSH's Avatar
Drives: '20 ZLE
You've got a lot of high hp customers. What are their most popular street tires?
2020 ZL1LE A10.
Old 11-02-2023, 10:25 AM   #25
Katech_Mike
It all depends on wheel size and application.
Toyo R888's and MT ET Street R's are popular
Old 11-02-2023, 06:34 PM   #26
JSH
JSH's Avatar
Drives: '20 ZLE
I'm not doing a 416 after all due to my reality check about the additional torque. It would just make bad traction worse. So, I'm looking for a built 377 SB, with a KaTech oil pump and 38% fuel lobe cam. Price and delivery remain.
How big a piston can you fit in this block?
2020 ZL1LE A10.
Old 11-02-2023, 09:06 PM   #27
Nimair.ZL1
Call my contact and he will take care of you
Old 11-03-2023, 08:54 AM   #28
KingLT1
KingLT1's Avatar
Who provided the reality check?
Your grams/cyl falls off up top. That tells me the supercharger is pasts it's efficiency point. It looks like a 1.7 stock blower on a 800-850whp car. A built 377 doesn't rectify that.
If you are sticking with the Eddie, I still think a larger engine with the proper heads/cam to match the displacement will work better with that Supercharger turned way down. Not 3.0 pulley down, more like 3.25. You make the same if not more peak power, less heat, and the torque shouldn't exceed where you are at now.
The ideal solution IMO, is to change power adders all together. The Eddie really isn't what you need for your goals at your elevation. You need a bigger unit. I don't know if the Whipple 3.0 will gain you much or move up to a F1x Procharger or Turbos. But that is what really needs to happen imo.
