Old 10-30-2023, 11:59 AM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
427 shortblock?
It looks like my thrust bearing is giving up the ghost.
I've always said that if I pull the engine again, I'll do a 427. So I will.
My plan has been to use my current valve train and heads, but the thought occurred to me that I probably need to change the cam too. Although my current cam works well, it's designed for something other than my current build and certainly not for a 427.
Thoughts?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-30-2023, 12:10 PM   #2
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
Thoughts?
You'll want a bigger cam. It really depends on what your setup is and what it will look like (boost only, nitrous, e85 and meth, 93 etc.) The small details will matter. There's a shop called ultimate engine solutions here in Texas that makes the baddest 427 engines at a really good price. If you'd like you can PM me and I'll give you the machine shop owners number. Just tell him Nimair sent you and he will take care of you. This is the same shop that built Justin Whites engine and you know how that car moves
Nimair.ZL1 is offline   Reply With Quote
Old 10-30-2023, 03:33 PM   #3
JSH
JSH's Avatar
Drives: '20 ZLE
Sure, send me the name and number thanks
2020 ZL1LE A10.
Old 10-30-2023, 03:40 PM   #4
Nimair.ZL1
I sent you the contact information in your messages
Old 10-31-2023, 06:53 AM   #5
Smokin19
Drives: 19' ZL1 A10, w/pdr
I liked the LS7 I last had in my 15' Z/28. Was built by Vengeance but, my current built Z would eat it.
Smokin19 is offline   Reply With Quote
Old 10-31-2023, 07:19 AM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I, still, think it was the cam that's been holding you back... It's not surprising it was the thrust bearing. I've seen many shops say that they wouldn't push the OEM short block past where you were (no offense or anything, of course). Did you say your blower went to sheet, too? Do you know what happened there? I'm just curious.
I know more displacement will give you more power, but I've seen some serious builds, that were stupid fast, go with less displacement, and go for more revs', with all the valve train goodies. Super stiff pushrods, shaft rockers, solid roller, Ti/Iconel, etc. I'm certainly no expert, and I know you've had some stupid-fast cars, so I'm not saying anything you don't already know.
I'm sorry for the complications, but am rooting for you, and excited to see what you come out with.
'20 ZL1 Black "Fury"
Old 10-31-2023, 08:41 AM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
Thanks for your input.
I, still, think it was the cam that's been holding you back --- Agreed, as of today, I'll do a new short block and cam.
It's not surprising it was the thrust bearing. Yea, I was warned.
Did you say your blower went to sheet, too? The blower is fine.
I know more displacement will give you more power, There's no replacement for displacement. In my case, more cid will allow me to spin the blower and engine slower and still make a little more power.
2020 ZL1LE A10.
Old 10-31-2023, 08:46 AM   #8
Katech_Mike
Drives: 2015 Camaro ZL1
We have 416ci shortblocks in stock and can build 427ci shortblocks in roughly 4 weeks.
Let me know if you need anything!
Katech_Mike is offline   Reply With Quote
Old 10-31-2023, 09:08 AM   #9
JSH
JSH's Avatar
Drives: '20 ZLE
416 would work too. I'll email you
2020 ZL1LE A10.
Old 10-31-2023, 09:20 AM   #10
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Can your chassis & suspension handle more torque? The bigger the bore, the less head gasket surface area to hold boost in. What are you goals with the engine or what are you hoping to gain? If you "just want a 427" that's cool too, just keep in mind both the positives and negatives that will come with it.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 10-31-2023, 10:04 AM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Right but we have to consider his elevation. a 427 would only need 15-16psi to make 1000 instead of the 22psi he was pushing. 427 @ 15-16psi with the right cam might actually be more useable than his SBE with the 2650 being way overspun and making 980wtq @ 2800 rpm. He was making 21-22psi @ over 7k DA. That would probably be 25+ at sea level. Hence why the thrust bearing let go.
Normally I wouldn't advise going bigger cubes but in this case it might be the way to go since he was maxing out the Eddie 2650 at his elevation. He really needs a bigger supercharger for that altitude or a bigger motor and less boost. Jm2c...
KingLT1 is online now   Reply With Quote
Old 10-31-2023, 10:18 AM   #12
jlaudio11
jlaudio11's Avatar
That is some very solid reasoning that I hadn't taken into account! Now ya got me thinking on the best way to go about something setup for that situation. Maybe a bump in compression to help make the most of what its got, hmm.
'20 Camaro LT1
Old 10-31-2023, 10:33 AM   #13
JSH
JSH's Avatar
Drives: '20 ZLE
The additional cubic inches is the way to go up here as I found out with my Sonny's 740 engine which was much more consistent than the smaller engines I competed against and here it makes sense because as King says I can put a 3-in pulley back on the supercharger. Slow it down to say 17,000 RPMs, shift the motor at say 6500 RPMs and make the same or more power plus having the primary benefit of a built bottom end
2020 ZL1LE A10.
Old 10-31-2023, 05:23 PM   #14
JSH
JSH's Avatar
Drives: '20 ZLE
Right but we have to consider his elevation... He really needs a bigger supercharger for that altitude or a bigger motor and less boost. Jm2c...
Do you think I've got enough injector and fuel pump for a 416 making 100-110% of current build, XDI 30+, Dsx LS 80#, HPFP delivery duration <93°
2020 ZL1LE A10.
