Old 02-11-2024, 06:44 PM   #15
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Has a solution been found through the dealer?
Mine is an early 22 model, mfg 09/21
Similar issues
Old 03-21-2024, 10:35 PM   #16
DylansZLE
DylansZLE's Avatar
Drives: 2022 Rapid Blue ZLE
My 2022 ZL1 1LE does not have a problem with GPS on PDR thankfully, but I have spoken to several others with 2022+ that have issues with the GPS as you described.
2022 Rapid Blue ZL1 1LE order ZNWPCX
Ordered - April 8, 2021 // 2000 - July 30, 2021
3000 - August 3, 2021 // 3100 - August 6, 2021
TPW - August 30
3300 - August 21 // 3400 - August 21
3800 10/18 // 4150 Oct 22
6000 November 1st
Instagram: dylanszle
DylansZLE is offline   Reply With Quote
Old 06-10-2024, 12:24 PM   #17
Alredline04
Drives: 2023 Camaro 1LE on order
Reporting in on this thread.
I have a ‘23 1SS 1LE. The PDR has not worked correctly since new. I’ve done 10 track days with it and I will usually see the symptoms as described above. Works for the initial session, but then the track map goes spaghetti and the times either dont record or the whole session is lumped into one lap time. Sometimes the data shows correctly in Cosworth toolbox, but this is not always the case. This leads me to believe it may be how the car is displaying the data I’ve been using micro center SD cards, class 10. Been using an individual SD card for each track.
Hope we can figure something out.
Alredline04 is offline   Reply With Quote
Old 06-10-2024, 12:45 PM   #18
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
I have been working with a group of GM Engineers. There will be a TSB soon to cover this, which involves replacing the existing Antenna with a new unit and moving it's location to in or near the shark fin.
In the meantime, I have found a replacement GPS antenna that I routed to the rear deck until the TSB is available that has 100% cured my issue.
GPS Antenna - Amazon
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 06-10-2024, 12:57 PM   #19
Alredline04
Good to know. I work at GM and contacting one of the engineers was my next step. You seem to have it well in the works already. Thanks.
Old 06-10-2024, 04:15 PM   #20
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Thx FollowMyLine
I'm nearly out of warranty. Do you know if the TSB will go past 36,000 miles?
Old 06-11-2024, 08:42 AM   #21
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
I don’t know if my issue is related, but I was at the track last weekend and I had to define the finish line each session otherwise I didn’t have the gps overlay. I read on here that after you set it once the car is supposed to remember it for the rest of the sessions as long as you’re using the same SD card. Can someone confirm if what I wrote above is correct? If so I wonder if I’m having gps antenna issues as well. I’ll try a different SD cars next week.
2012 Shelby GT500 with VMP Gen 3R.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 08-20-2024, 11:55 AM   #22
redsoxjaz
redsoxjaz's Avatar
Drives: 2021 2SS-1LE-A10
I just found this thread and I am hopeful "again" that maybe a fix is on the way, and I may even try the gps module linked from amazon. Anyway, here is what I have been through and thank you to travislambert, he and I spoke off and on last season. My car is a '21 2ss 1LE A10 so it is an earlier model that the '22 and up referenced. I'll try to keep it as short as I can.
I purchased my car in December of 2020 and began tracking it in July of 2021. I have over 500 laps at my local track which hosts a track day once a month from April - October. I don't miss many. My PDR system has had the gps issues from the start. The first dealer trip where I raised awareness was a waste of time, they paid no attention to the PDR and assumed it was tied to the navigation system and performed a software update. After that failure I decided to purchase race chrono pro and an external gps, this got me through the '22 season and I've grown to like it especially as an in car timer. 100% would recommend. Near the end of the '23 season I figured I'd try to get this PDR thing fixed again. Went to a different dealer whom actually were great to work with and offered to replace the PDR unit (not the antenna) under warranty. Well, that didn't fix it. Obviously the gps antenna is the issue here, which has been mentioned. Like others, my car picks up signal great during session #1 and then again during session #4 which occurs after lunch where my car has been sitting for an hour and a half. On the in-between sessions I have even tried starting the car and not moving it for 5-10 minutes to allow the gps to locate, no luck
While what I am sharing doesn't help matters I figured another story of this issue may be seen and potentially get that TSB moving along quicker.
Fingers crossed
~AJ
redsoxjaz is offline   Reply With Quote
Old 09-08-2024, 09:13 AM   #23
FollowMyLine
Driver for Hire
Well, I finally got around to making this video. I wanted to test it out first on my own car, before making a video for others. It works, and it's a solution to the funky GPS antenna until GM releases their TSB for the 22-24 models.
You may see some images pop-up that look familiar from this thread! Travis, I really wanted to use your middle finger track map but decided not to.
Luan Zeqollari
YouTube Channel
Old 09-10-2024, 10:30 AM   #24
Caerus
Caerus's Avatar
Drives: 2023 Camaro ZL1
Thanks for the time and effort to put this video out. It's a great DIY fix for the problem.
2023 Camaro ZL1 6MT Summit White
Caerus is offline   Reply With Quote
Old 04-06-2025, 10:10 PM   #25
FollowMyLine
Driver for Hire
My pleasure!
Luan Zeqollari
YouTube Channel
Old 04-07-2025, 07:27 PM   #26
FollowMyLine
Driver for Hire
Originally Posted by travislambert View Post
It appears that there may be an issue impacting the PDR GPS signal with many, most, or all after a certain date Camaros (with PDR). The issue appears to have started late in the 2022 model year the best I can tell.
The issue is a problem with the quality of the PDR GPS signal on its second use after a long period of no use. In other words, your PDR likely works fine at least once. It will continue to work for the remainder of that ignition cycle for as many videos as you'd like to record. However, if you turn the ignition off and within a few hours attempt to record another PDR video, you may notice that the GPS signal is weak or nonexistent. This, of course, is causing issues with any map overlays, lap timings, etc. If you let the car sit overnight, the PDR GPS will work perfectly once again for one ignition cycle. After that, the GPS signal quality is poor/non-existent. Unhooking the battery momentarily does not work, unfortunately. It seems the car must sit and enter a long sleep cycle before whatever is causing the issue resets. Sometimes I leave my car running between sessions just to have a working PDR.
Since late 2016, I've owned and tracked a 2017 Camaro ZL1 without any PDR issues. Last year I purchased both a 2023 Camaro SS 1LE and a 2023 Camaro ZL1 1LE. Both new cars have the PDR issue described above.
On the 2023 SS, I have replaced the GPS antenna with a new antenna as well as the older revision that was in the 17 ZL1. Neither made a meaningful difference. I've tried two other PDR modules. One was from an early 2019 build and the other was from an early 2022 build. These two modules as well as the one that came with my car all have the same behavior.
I know of a couple of other people tracking newer Camaros and they are also having the same issue. If you're having this issue, please take your car to the dealership with sample PDR files and have the dealership contact GM. I believe the folks at GM are aware of the issue but perhaps don't know the cause just yet. The more cars we can get to the dealerships the more resources they'll put into fixing the problem.
If you are aware of this problem and have a workaround or solution, please share it.
I received an update today, it looks like there should be a TSB coming by mid-May.
Luan Zeqollari
YouTube Channel
Old 05-09-2025, 02:10 PM   #27
FollowMyLine
Driver for Hire
This is more like end of May, beginning of June...
Luan Zeqollari
YouTube Channel
Old 08-18-2025, 05:29 PM   #28
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Does anyone have the TSB?
The dealer says they haven't heard of it.......
