#15 |
I agree. Coulda saved my money.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#16 |
See you at the Track!
Drives: 2022 Rapid Blue SS 1LE Join Date: Feb 2022
The ZL1is a $70k car the Granatelli wires are $200. It has been proven that they are the best, why get anything else?
https://youtu.be/aUfpkYMD1rI
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD) |
#17 |
#18 | |
Black lightning
12inch? Got it
[ 2021 Camaro ZLE 10 speed
#19 |
![]() Drives: 2018 Camaro SS Join Date: Sep 2009
I tried running MSD’s and the JDP Taylor wires with the braided sleeves and both burnt out quickly from touching a rushed to production, high dollar header, that was ceramic coated. I ended up swapping my problem header out with a revised version and then went with these ceramic MSD’s from Ton’s performance. The bend turns away from the primaries very well and it’s certainly not going to burn through like the other two brands. No matter what you choose understand that those sleeves do absolutely nothing if it touches the primary. These new wires do a great job but a decent header is a must as well.
#20 | |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I have ARH 2" headers and the MSD Wire weren't touching and still burned one. I switched to Granatelli and no problem whatsoever. |
#21 | |
#22 |
![]() Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
Have TSP on my ZL1 and Granatelli on the C7Z. Both have worked without issue.
#23 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
My Granatelli wires lasted exactly one five session track day at Road Atlanta. I replaced the melted wires and installed DEI boots and the wires seem to be holding up fine now. If you have headers you will definitely need the boots. My headers are ceramic coated. I doubt if I could have made it out of the driveway with uncoated headers and unprotected wires.
Baby Blue
#24 |
![]() Drives: Chevrolet Camaro Join Date: Feb 2022
A second on the Katech plug wires, which replaced MSD’s, and remedied a misfire on my modified LS7. MSD’s removed from my car were not damaged by physical contact with aftermarket Kooks headers, and had also been recently replaced. Boots have always covered the plug and MSD plug wire connector at the plug. Quality / durability of MSD’s plug wires has reportedly declined in recent years.
#25 |
![]() Drives: 2022 Vivid Orange LT1-M6 Join Date: Dec 2015
I'm looking at the GPI,TSP and Granatelli wires. After shipping and tax, they are pretty close in price so I'm leaning towards the Granatelli wires, but it looks like they are 10". Anyone think this is enough for 2" ARH headers?
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph |
#26 |
Moderator
Granatelli wires FTW. I have 2” primary headers as well.
#27 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
+1
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#28 |
Am i looking at the right ones?
https://granatellimotorsports.com/i-...lug-wires.html https://granatellimotorsports.com/i-...lug-wires.html
