Black lightning
Texas speed plug wires or Granatelli
Msd (as usual) plug wires were the cause of my misfire in my prior post even with boots on them. Never again. Well anyway my tuner suggested Texas speed they are shorter at the spark plug and angle straight up avoiding the headers completely. I did some research and seems granetelli is the best but twice the price which I’m not worried about. Any experience with either one?
[ 2021 Camaro ZLE 10 speed
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i have msd but i did it again id go with granatelli
![]() ![]() ![]() Drives: 2023 ZL1 - All Bolt On's Join Date: Dec 2022
I just bought custom length 0 ohm Granatelli's for my Katech valve covers and coil relocation kit ! Waiting for them to arrive !!!
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I had MSD and one plug git burned so I bought the Granatelli with there heat shield and no problem they look nice also. Get the high temp wires which are a little more but your safer.
Black lightning
Gotcha
I put ACCEL w/ceramic boots on mine but seriously doubt I realized any benefit over OEM. Save your money unless you're trying to dress up your engine bay.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: Last edited by JSH; 01-19-2023 at 12:30 PM. |
#7 |
Moderator
Granatelli ones have been absolutely perfect. No issues at all past 2 years I’ve been running them.
#8 |
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
I run the Granatelli wires with no problems.
#9 |
![]() Drives: 2018 Zl1 Camaro Join Date: Feb 2018
I have switched 3 times now and absolutely love the KATech High Performance Wires. They connect solid, shrink coated at both ends and much thicker then 8.5mm. Had to switch boots over to ringless DEI Titaniums to fit.
Big Gulp|NW103|SW Headers|UHO CATS|XPipe|Borla Atak|MM CC|Kong Ported|NSX|ATI Damper|DSX 9.45 Lower|ZPE 2.5 Upper|DM Tensioner|FW Green Belt/BTR Gen V LT4 Cam w/32% lobe/BTR VVT Lockout/Pratt & Miller Chain/BTR Pushrods,Valve Springs, Retainers, Hydraulic Lifters & Guide Plate, Trunnion Roller|Katech Valley|KaTech Valve Covers|MSD Coils|DSX E Sensor & Aux Pump|ICT Water Pump|Katech Oil Pump|Cordes & Mishimoto Expansion Tanks|P3 Gauge|LC-2 Wideband Sensor|KaTech Wires|DynoJet Tuned
#10 |
I run the Speed Engineering, especially if your running headers, they make their own wires and you can buy them in 10" which is standard but the 12" work best with the headers. I've run them on my 16SS, my C7 and 2022 Lt1 even though I don't have headers on it.
#11 |
Granatelli are top notch, but for a cheaper option the Speed Engineering are solid as mentioned above...
#12 |
Honestly, I think King agrees with me on this, there is nothing wrong with the stock wires unless you are just wanting a better-looking setup. I haven't installed them yet on my Lt1 but have them ready to go as soon as I get motivated to install them, been cold here in Missouri so no big hurry since the tracks don't open till March. I made 707/662 on the stock GM wires.
#13 |
#14 |
Black lightning
Hmmmm I do have speed engineering headers let me read up on this
