Old 01-23-2023, 01:59 PM   #15
ctrlz
I would try to check the connections in that area and possibly resolder.
This post shows some photos of the whole thing. Your impacted area appears to be lower left in the first photo, and lower right in the second. Just based on proximity, I'd be worried about how those devices affect the brown connector. since brown male goes to brown female, that would be the x4 connector which is communication with car's main data buses.
https://www.camaro6.com/forums/showp...2&postcount=12
An old post with the pinouts for x1, x2, x3, and x4:
https://www.camaro6.com/forums/showthread.php?t=488428
Old 01-23-2023, 02:10 PM   #16
lynyrd
lynyrd's Avatar
Drives: Camaro 2.0 LT 2018
Send a message via Skype™ to lynyrd
Thanks for the links, I cleaned everything, I have no sound, I think the amp is faulty.
Should the amp be reprogrammed if it is changed?
2018 Camaro 2.0 LT Turbo, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights
lynyrd is offline   Reply With Quote
Old 01-23-2023, 03:16 PM   #17
ctrlz
If you find a new (or used) amp you may need dealer software to "marry" it to the car.
EDIT: Looking on ebay there are (not unexpectedly) several part numbers for the Bose amp. You will need to look at underside of amp to get that number. I'm wondering if you buy a new one (some model numbers are cheaper than others), you may not have to unlock it using the donor VIN as you would with a used amp.
AND...
From what I read on other forums, a new amp is plug-and-play. A used amp needs to be unlocked.
Old 01-25-2023, 05:19 AM   #18
lynyrd
lynyrd's Avatar
Originally Posted by ctrlz View Post
If you find a new (or used) amp you may need dealer software to "marry" it to the car..
I went to a US car dealership, they swapped my car's Bose amp for an amp from a Camaro that was there for maintenance.
The radio worked, my amp died, so as long as the amp has the same serial number it shouldn't be programmed with the car,
Old 01-25-2023, 06:28 AM   #19
ctrlz
So you got one that works, or now you have to search?
Old 01-25-2023, 08:40 AM   #20
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
If I took my car to a dealership and they "borrowed" any of my parts to try to diagnose someone else's nightmare I'd be F*(K1NG PISSED! No guarantee the "borrowed" part(s) don't get messed up and they fail on the unsuspecting customer later on, who then has to pay for it because the dealership will deny anything and everything! Wow, just wow.
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
Old 01-25-2023, 08:51 AM   #21
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
^^^ what he said
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 01-25-2023, 09:02 AM   #22
adamjwilson
Drives: 2022 Camaro 2SS A10
Surprised any reputable Chevrolet dealership would do this (but it does not specify, only "US car dealership", so I assume it is a Chevrolet dealership).. I am sure there is more to this story that is being told here. The liability is enormous for this dealership.....
Why not just take it to a Chevrolet dealership and fix all these problems and be done with this thread?
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 01-25-2023, 09:30 AM   #23
ctrlz
Wow, just wow.
Since he is in Belgium, I'm guessing they are dealing with limited parts and resources. As to why dealer is not fixing the car, probably because it is cheaper if he fixes it himself. Dealer will probably refuse warranty coverage due to water intrusion.
Don't mind this thread one bit. Eventually we will all be out of warranty and may need to buy modules off ebay.
Old 01-25-2023, 09:54 AM   #24
adamjwilson
Makes sense.. spend 10 dollars to save one
If you can't afford a camaro, go buy a mustang
Old 01-25-2023, 05:23 PM   #25
AmericanMike
AmericanMike's Avatar
Drives: 2017 Camaro SS FIFTY
what is with all the shade being thrown? No doubt the Camaro can be afforded because I'm sure it is at a hell of a premium compared to here. Other countries are not the same as the US and have Chevrolet dealers on every corner.
The other post was correct, parts are limited, they have to make do with what they have. Not a fan of swapping parts from customer's cars though, but it is what it is.
AmericanMike is offline   Reply With Quote
Old 01-26-2023, 02:02 AM   #26
lynyrd
lynyrd's Avatar
The parts had the same number and it was just the amplification that had problems, the rest worked normally, the failure was only due to the amplifier.
Replace a part with another that are exactly the same, I don't see where the problem is.
In Europe, there is no longer a Chevrolet dealer, Opel is taken over by GM, which in theory must take over Chevrolet.
Since he is in Belgium, I'm guessing they are dealing with limited parts and resources. As to why dealer is not fixing the car, probably. Dealer will probably refuse warranty coverage due to water intrusion.
New parts in Europe are impossible to find, you have to order in the USA, there are no more Chevrolet dealers in Europe and the warranty is three years.
Makes sense.. spend 10 dollars to save one If you can't afford a camaro, go buy a mustang
It's not to save repairs, if I order a part that I know how to replace myself, why go to a repairer, you go to your dealer to replace a fuse? Unless you have two left hands, you do it yourself!
I replaced my fuse box, there is a "dealer" in Luxembourg, a fuse box, 600$ and 5 to 6 weeks to have it, ordered in the USA, all costs, 152$ and received in 15 days .
Do you think I spend $10 to save $1?
Don't say anything without knowing!
The Camaro in Europe costs + or - $4000 more than in the USA.
It is no longer imported, so no more parts, if you want one, you have to order it in the USA and take all the steps to ensure that it meets European standards.
Old 01-26-2023, 06:41 AM   #27
adamjwilson
[/QUOTE]
Old 01-26-2023, 08:25 AM   #28
TP2SS
TP2SS's Avatar
The problem is, a dealer took a part THAT DID NOT BELONG TO THEM, and used it to diagnose someone else's car. Your car. You only know that the problem was amplification AFTER they did so. There was no guarantee that installing the other amp could have fried it, then the OTHER guy ends up with a shitshow problem (in Europe, where HE will have a hard time fixing it too). The only way to properly test electronics is using a test procedure, on a bench, with the proper equipment. That dealer took a chance with SOMEONE ELSE'S property. I get it's Europe. I get there are no Chevy dealers there. I get your dilemma, but that's the chance you take owning a car in a place where there's little to no tech support for it.
Hyper Blue/Ash Gray
A8
Dual Mode Exhaust
Navigation
