Old 03-06-2022, 01:46 PM   #15
Trochoidal
Drives: 2017 Camaro 2SS A8
Originally Posted by 6spdhyperblue View Post
I grabbed one. Was gonna try it in the a10 this opening weekend but the weather didn’t cooperate
You and Duramacr1 are on top of this one.
The 31whp gain was on a car making over 900whp. You also need a 103mm TB to maximize the gains.
Brett also said he seen a 1.5 tenth reduction and 1.5mph gain at the track on a 600whp NA combo. He didn't say if that was using a Rotofab or OTR setup.
Yeah I get that’s it’s not the same as NA. I was just sharing data.
it's also fair to note that the velocity stack replaces the air filter. i mean, i'm all about performance, but that's where i draw the line on a street car haha. also i imagine it would require a dedicated tune to compensate for the maf signal. i don't see swapping the vc at the track on an otherwise stock/bolt on car going well at all.
Amen! I wouldn’t be running around on the street with no filter. It’s a good line to draw.
Yes you have to tune for the airflow change. You could tune for the Bellmouth and leave it as is even if you swap back to the filter. It's just going to run a tad rich in PE. Not enough to cost much power or hurt anything....especially NA setups.
Good points. If this resulted in a viable option, swapping the filter and tune before leaving the track wouldn’t take much time.
Originally Posted by Vtor_ZL1 View Post
* Filter not shown ?
Because race car?
Old 03-06-2022, 02:28 PM   #16
Joshinator99
Moderator
Joshinator99's Avatar
I just ordered one, and will dyno test it back to back vs the air filter on my Big Gulp this spring too. Just waiting for my CNC ported Whipple to come back…
Old 03-12-2022, 10:23 AM   #17
17camaroSS
17camaroSS's Avatar
Drives: Chevy Camaro SS
i think catering to that age old cone on a stick rotofab design is a waste of time. go over the radiator and stop wasting money on stuff returning $100/hp.
bell mouth has been around. i've seen it on some na cars the past couple of years. granted they are no maf race cars with hi rams and no other induction.
This is how I feel about it as well. My own OTR setup gained 2.5mph on my bolt on car with a hi ram with the bellmouth on the end of the OTR tube. It was also a design that everyone said wouldn’t work. Still has a MAF as well.
2017 1SS:Hi-Ram, FBO, OTR ram air,
Circle D converter.
Previous PB: 11.07 @124 1/4
7.1 @100 1/8 1.6 60’ w/2” longtubes,
95mm hi-ram,
OTR ramair, flex fuel
17camaroSS is offline   Reply With Quote
Old 05-08-2024, 09:37 AM   #18
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
Any update on this for those who ran it? Any improvements? I see pray had a few back in stock on FB recently and I was researching this post was the first I seen. So just curious.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
Old 05-08-2024, 02:13 PM   #19
Joshinator99
Moderator
I saw about 15-20 WHP back when I was making low 900’s WHP. Which sounds good, but it really raises heck with your MAF scale. Plus it deletes your air filter…the one time I thought about running it at the track, I had a blower belt snap and launch a ton of debris everywhere (including the hood liner!). If I had run the Pray bell mouth all the debris would have all been sucked into my motor, so I was really glad I kept the air filter on.
Old 05-09-2024, 06:04 PM   #20
Blackmonba6Gen
BLUPRINT_1LE
Great point made! That would've really sucked to get debris into the motor. It seems like until he can up up with a small filter to cover the bell mouth its not worth it.
Thanks for responding.
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 05-09-2024, 08:39 PM   #21
Joshinator99
Moderator
No problem! The belt really wrecked some havoc for sure. For your enjoyment lol:
Old 05-09-2024, 08:51 PM   #22
Blackmonba6Gen
BLUPRINT_1LE
OMG! That’s crazy a belt did that much damage!!
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 05-09-2024, 09:45 PM   #23
Joshinator99
Moderator
Yep! Broke off the hard shell connector for the crank position sensor, wrecked the other two belts, sheared off the thermostat nipple (billet now lol), sprayed coolant everywhere, etc. I thoroughly cleaned out the entire engine compartment, yet 18 months later I will still find the occasional piece of belt in weird spots.
Old 05-10-2024, 05:53 PM   #24
brokedad
Drives: 2017 Camaro ss
I wonder what what the numbers would be if you just took the air filer off without any bell mouth? I know in the past back in the early 90’s we would take the air cleaner off while at the track for a small gain. Do you think adding the bell mouth makes that much difference? Not knocking on any product just posing the question. I would think you would still get most of your gains by just removing the filter.
brokedad is offline   Reply With Quote
Old 05-10-2024, 08:40 PM   #25
Joshinator99
Moderator
I think it would destroy your MAF scaling even worse than the bellmouth does… the air filter helps to straighten the airflow across the sensor, giving you repeatable results. Even the bellmouth does to some extent too since it helps direct air into the tube, but even that requires some rescaling. Nothing on the end will be a mess, is my guess.
