Old 08-21-2021, 05:49 PM   #15
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Originally Posted by IneedAZ View Post
I am concerned with it messing up the pulses, that is why I didn't want to run 2. Maybe it's not an issue.
On mine it took out all the rasp and no drone. I’m very pleased with it and finally done making adjustments to my exhaust LOL.
CW3SF is offline   Reply With Quote
Old 08-21-2021, 07:14 PM   #16
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
How do you like the mbrp resonators? Did you install all of it at once? Would you be able to make a sound clip of your setup?
Old 08-21-2021, 07:30 PM   #17
CW3SF
CW3SF's Avatar
The MBRP resonators are great. I did the exhaust in steps, axleback/midpipes/linkpipes/headers/resonators. I kept adding parts till it sounded how I wanted it. The resonators gave the exhaust a deeper rumble. I posted clips in post #13 of this thread.
Old 08-22-2021, 11:29 AM   #18
IneedAZ
IneedAZ's Avatar
I use Vibrant 1795 resonators on mine right between the Kooks green cats and AWE X-pipe.
What made you choose those? Did you look at others?
Old 08-22-2021, 02:06 PM   #19
IneedAZ
IneedAZ's Avatar
Anybody using the Borla 400939? Considering adding those. A lot of people are using Borla 60608 but those are not 3inch, so that leaves Vibrant 1795 or MBRP R1013 if I don't do the Borla 400939.
Old 08-22-2021, 05:23 PM   #20
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
The long side of the borla 60608 can be expanded, and the other end just needs a 3” to 2.75” reducer welded on to Connect to your S pipes and then welded.
Took my buddy maybe an hour.
Edit: we cut about 3/4” off where the slip fit cuts were then expanded that end to 3” then welded on a 3” piece to the 60608 which was then welded to my s pipes.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 08-22-2021, 05:26 PM   #21
IneedAZ
IneedAZ's Avatar
I do like the size of the 400939 though..3.5" overall diameter is pretty good being that the inlet is 3"
Old 08-22-2021, 05:31 PM   #22
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Length really matters more on the sound effect. It’s not going to affect flow.
Old 08-22-2021, 05:43 PM   #23
IneedAZ
IneedAZ's Avatar
I think the MBRP R1017 has the longest body of what i have seen at 22". Most seem to be 10 to 20".
Old 08-22-2021, 07:10 PM   #24
CW3SF
CW3SF's Avatar
I used R1013s. 16” body and 20” overall. 3” dia inlet and outlet. It produces a nice deep tone with no rasp and no drone.
Old 08-22-2021, 10:50 PM   #25
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
Thanks for the clips. You really have me thinking of adding those into my system if possible.
I have 2” CSP into Stainless works catback and there is just not as much control to the tone as I’d like.
jvandy50 is offline   Reply With Quote
Old 08-23-2021, 06:41 AM   #26
IneedAZ
IneedAZ's Avatar
Which SW mufflers are using? I went with the Legend series.
Old 08-23-2021, 11:28 AM   #27
jvandy50
well, i ordered mine before they started doing the 3 different choices...and i'll be honest, i have no idea what muffler i have lol.
part number is ca16rvcb and i see on beefcake racing's site that catback is expanded to 3 choices now.
it sounded awesome and on the mild side before headers, and that's why i picked it. but the headers really jacked up the mild part of that equation
do you happen to know what muffler was standard before the choices?
Old 08-31-2021, 07:23 PM   #28
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Don’t attempt to use that muffler at that power level. Your going to have a serious restriction.
I would politely disagree. I’m at 906 WHP at 14.6 pounds of boost with that Magnaflow muffler installed (in addition to AWE resonators and AWE Touring mufflers).
