Old 08-21-2021, 08:02 AM   #1
IneedAZ
IneedAZ's Avatar
Resonators, who is running them?
Now that I put the Stainless Works Legends on the car it is very loud in lower gears. I am thinking of adding resonators. I cannot run the Magnaflow dual in/out cause I don't want 2 xpipes in the system. I have ARH 2" into a catless ARH long system and now into the SW Legends.
So what are you running and do you like it?
Old 08-21-2021, 08:13 AM   #2
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
I haven't seen the Legends catback system, but assuming it similar to others, you wouldn't need to run two x-pipes. The magnaflow would replace your x-pipes. Cut out your current x-pipes and weld (ideally) or clamp in a magnaflow resonator.
Adding some green cats would tame it down a bit too, but I suspect you opted for catless for a reason.
YouTube
Old 08-21-2021, 08:21 AM   #3
Z OH 6
Drives: 2024 CT5-V Blackwing
I use Vibrant 1795 resonators on mine right between the Kooks green cats and AWE X-pipe.
Old 08-21-2021, 08:51 AM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’m running:
2” ceramic coated Dynatech headers
3” AWE resonators
Dual 3” in/out Magnaflow muffler
AWE Touring mufflers
Car is still not quiet...LOL. But the Magnaflow took enough of the edge off for street use.
Old 08-21-2021, 09:26 AM   #5
FoundNemo
Drives: 2019 ZL1
My buddy has CSP 2" headers, GESI green cats, dual Magnaflow 18" x 3" resonators and Corsa Sport mufflers. Zero rasp, very tame until you get on it.
FoundNemo is offline   Reply With Quote
Old 08-21-2021, 10:48 AM   #6
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Would there be a downside to running a magnaflow x pipe muffler with the stock x pipe? I was hoping to tone it down a little by running it somewhere before the factory pipe and adding some flex pipes. Now I'm wondering if I should run resonators instead. Anyone running these mbrp ones?
https://mbrpexhauststore.com/r1013-m...iABEgLEofD_BwE
Old 08-21-2021, 11:06 AM   #7
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
The magnaflow muffler is NOT a true dual. It’s a double Y with a single 3” pipe inside . On the resonators I use the Borla 60608 which replaces the mid-pipe section.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 08-21-2021, 11:30 AM   #8
bullitt4110
Drives: 2019 ZL1 1LE
I have LG headers, rotafab, borla s-type cat back and e-50. I added the dual in dual out magnaflow and cut out the x-pipe from the headers, so only 1 x-pipe still. Didn’t loose any power with this set up and made the tone very nice and livable.
2019 ZL1 1LE - satin steel gray metallic M6
2009 Z06 - sold
bullitt4110 is offline   Reply With Quote
Old 08-21-2021, 11:44 AM   #9
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
It’s not a true X-pipe.
Old 08-21-2021, 12:52 PM   #10
IneedAZ
IneedAZ's Avatar
At what power level are u guys at with the Magnaflow? Seems it would be to much back pressure going into a single pipe at higher hp levels? I'm at 800rwhp.
Old 08-21-2021, 01:02 PM   #11
bullitt4110
I’m lower at 663rwhp.
2009 Z06 - sold
Old 08-21-2021, 01:06 PM   #12
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Don’t attempt to use that muffler at that power level. Your going to have a serious restriction.
Old 08-21-2021, 04:39 PM   #13
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Just curious but why don’t you want two x-pipes. I have ARH headers, ARH high flow cats, ARH mid pipes with x, 2 16” MBRP resonators into AWE mid pipe with x into AWE Touring catback.
http://youtu.be/y3fxv8v2-e4
http://youtu.be/BJf08gYa1ug
CW3SF is offline   Reply With Quote
Old 08-21-2021, 05:44 PM   #14
IneedAZ
IneedAZ's Avatar
I am concerned with it messing up the pulses, that is why I didn't want to run 2. Maybe it's not an issue.
