Old 08-10-2021, 07:51 PM   #15
G61LE
G61LE's Avatar
Drives: 2019 Camaro ZL1 // 1LE
Originally Posted by Zl1+911 View Post
Here is what I do - Go to Goodyear, talk to the tech…take your specs, the computer for hunter shows ZL1 track as a setting …use that if need be. The work to do the alignment is pretty straightforward- the only tricky part is the front with the screw to adjust. I like the Goodyear and my tech, have a 3 yr alignment for $250 and tip him $20 each time….
+1
G61LE is offline   Reply With Quote
Old 08-10-2021, 07:58 PM   #16
20Bluezl1
What specs are most of you guys running for backroads street driving and track?
Old 08-11-2021, 02:11 PM   #17
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Eyeballed my fronts yesterday. The inside edge wear isn't bad at all even with the track alignment setting. If anything, it actually looks like I am wearing the outside a little faster.
I track about once every month, FWIW.
Performance supplement states you can use -2.0 front camber and -1.5 rear camber for an SS 1LE and ZL1(non-1LE) for tracking.
From the factory, it's -1.0 camber all around.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 08-11-2021, 03:59 PM   #18
blahson
meep meep
Drives: 2018 ZL1 1LE
AutoGlitz in Hollywood, good alignments for a good price.
Elite Roads is another good shop, although I haven't been there for 2 years.
Call Redline Motorsports and ask who they recommend.
Apex Alignment in [super] south miami will get you an impeccable track alignment.
I heard Bello Motorsports in West Palm is good for track alignments too, never tried.
blahson is offline   Reply With Quote
Old 08-11-2021, 04:25 PM   #19
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
This is my street alignment if it helps.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 08-11-2021, 10:13 PM   #20
Juise99
HPDE
Juise99's Avatar
Drives: 2019 Chevy Camaro ZL1 1LE
If you turn the strut hats yourself it's just a normal alignment to the spec you provide. My track alignment was $90. It took me about 45 minutes to turn the hats.
Juise99 is offline   Reply With Quote
Old 08-12-2021, 07:49 AM   #21
dengel223
Drives: 21 ZL1 A10
Originally Posted by zx9rmal View Post
I'm having a hell of a time finding someone who knows how to do the track alignment down here in Ft. Lauderdale. Geez, it's not rocket science.
My dealer supposedly has an alignment "expert", but he was clueless.
There is one local dealer that claims to be experienced doing track alignments, but they want $300, because they say it's a ver "involved" procedure. Give me a ****ing break.
Can anyone recommend a shop in the Ft. Lauderdale area?
Thanks.
Hi,
I used Jacob over at Elite Roads. Give them a buzz.
https://eliteroads.com/
dengel223 is offline   Reply With Quote
Old 08-12-2021, 09:36 AM   #22
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Thanks guys. I'll check out Elite Roads. Redline doesn't do it but recommended OK Tire in Pompano Beach.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 08-13-2021, 12:01 PM   #23
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Originally Posted by dengel223 View Post
Hi,
I took your recommendation and got the alignment done today at Elite Roads.
Jacob is a good guy. He took a lot of time. Unfortunately, it wan't until I got home and really looked at the printout that I noticed front toe to be at - and not +. What do you guys think? Can I leave until I get it done again in maybe 3K miles?
Sorry for the sideways image.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 08-13-2021, 12:15 PM   #24
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
thats alot of toe in the front...
Old 08-13-2021, 03:23 PM   #25
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
I called the shop and the guy sincerely apologized. He misread the front toe reading. Told me to come right back to fix it. Here's what I now have. A little over on the toe in front, but otherwise ok, yes?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 08-13-2021, 08:46 PM   #26
atx_traveler
Drives: blue velvet
are you planning on tracking your car? it doesn't look aggressive enough if you are. for DD it's perfect.
atx_traveler is offline   Reply With Quote
Old 08-14-2021, 05:44 PM   #27
Techdude99
Techdude99's Avatar
After several track alignments at various Chevy stores, I would suggest turning the hats (this trips up some Tech's) yourself and then go anywhere you trust that has a Hunter rack. It's not difficult and all the specs are in the machine if the software is 2018+.
I've paid anywhere from $95 to $129. Again, it's not difficult and is only slightly more time consuming than a traditional 4 wheel alignment.
Techdude99 is offline   Reply With Quote
Old 08-16-2021, 11:14 AM   #28
kropscamaro16
here is mine but im heavily modified now lol
