Old 03-30-2021, 04:01 PM   #15
JustDo1nMe
Drives: 2018 ZL1
Originally Posted by Can'tHave2MuchHP View Post
Guys, crazy coincidence. Exact same problem with my 2018 this week. I tested coils and wires; all good. Thought for sure it was an Injector. I moved the plug to another cylinder and the problem followed it. Replaced the plug and good as new.
Same issue confirmed with mine.
JustDo1nMe is offline   Reply With Quote
Old 10-09-2025, 06:16 AM   #16
Hheatt_ZL1
Hheatt_ZL1's Avatar
Drives: 2018 ZL1 6spd
I have a 2018 Zl1 with 60k on the clock that had the same issue, ended up being a bad lifter #2 cylinder exhaust lifter and it made no noise.
Hheatt_ZL1 is offline   Reply With Quote
Old 10-09-2025, 08:06 AM   #17
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - All Bolt On's
JustDo1nMe & Haeatt_ZL1 - Did you have the same P0300 code as the OP or a different code? Reason I ask, I had P0300 (Random Multi Cylinder Misfire) happen twice since owning my car. Soon, I'm having my car mod'ed again, getting CAM, heads and a few other things. So, if I was experiencing a bad lifter that was causing the issues. I think this would solve future issues related to those specific factory parts since they are being replaced.
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
Old 12-31-2025, 08:17 PM   #18
BIGTIME
BIGTIME's Avatar
Drives: 2018 ZL1
My 2020 ZL11LE just did this for the second time in 10,000 miles. I went wide open throttle for a couple of gears and got the flashing light that went off in about 30-40 seconds. Both times the car had been sitting for about a week. First time the dealer said it was probably due to low voltage. Now the car is at 41,000 and I’m thinking of replacing the plugs early to play it safe. I’m also going to toss in a can of BG44K DI cleaner. Crazy that the dealer wants $1100 replace the plugs and $983 for the coils. I’ve done plugs and coil packs on other cars myself so 2k sounds insane. Removing the coolant reservoir isn’t the end of the world and I know the passenger side rear cylinder is harder to get to so I might pay to have the plugs and wires done but I’m pretty sure my 13 yr old could replace 8 coil packs.
Anyway, I charged the battery, going to add some BG44k to the fuel tank, and will look into replacing the plugs early.
Any tips on doing that passenger side rear plug ? Small ratchet? Large? Extension ? Thanks in advance
BIGTIME is offline   Reply With Quote
Old 01-02-2026, 10:43 AM   #19
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
I'd buy the plugs and film me changing them in their parking lot, then walk back into service to tell them to go Fvck themselves, I hope they go out of business and post it on the internet.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 01-02-2026, 11:50 AM   #20
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Dont forget that knock sensors will cause flashing check engine lights too. Flashing check engine light is a failure that is destroying the catalytic converter. Not just a misfire. If your at high boost and your fuel quality isn't up for it then you could get a pinging situation that you could probably see in your spark knock data.
Old 01-02-2026, 04:24 PM   #21
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
No kidding. What a farce. Stealership strikes again.
Mods being installed-
