Old 01-11-2021, 02:26 AM   #1
JustDo1nMe
Drives: 2018 ZL1
Exclamation Misfiring Issues 2018 ZL1 (Cyl #3)
Hello, hoping I can get some help or see if anyone else has had a similar issue...
My 2018 ZL1 has just about 3000 miles. It was dyno tuned with a rotofab intake, ARH headers, borla cat-back, and LT5 throttle body.
Just before winter started, I was out on a normal cruise when the car started misfiring. It through a CEL (P0303) Misfire Cylinder #3. Along with the CEL, the instrument panel displayed errors (service rear end/axel). The codes go away when the car is shut off and then turned back on but will re-trigger once the car goes over 2k rpms. Even when codes are cleared... you can tell it has a misfire in the idle.
I have not tried any trouble shooting yet.
Any feedback is greatly appreciated. Thanks in advance!
JustDo1nMe is offline   Reply With Quote
Old 01-11-2021, 06:29 AM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Things to look at in order of likely hood:
1) Check 2nd spark plug on the driver side from the front (#3), make sure it is fully seated, you should get 1-2 clicks out of the coil pack and 1 click on spark plug
2) Check spark plug for proper gap (make sure it didn't get dropped or something weird), swap plug to different position if issue continues to see if it follows plug and then replace
3) Check coil pack wiring, check for full insertion then remove and check for broken pin lock(s) causing recessed contacts when inserted
I've had #1 and #3 happen
Old 01-11-2021, 07:07 AM   #3
PROMETHEUS
PROMETHEUS's Avatar
Had the same thing happen to me about 8 months ago, but Cylinder #1. Same display codes! Bad plug....replaced by dealer.
Old 01-11-2021, 07:46 AM   #4
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Agree with above. There have been posts with similar issues which turned out to be a loose plug wire or a bad plug. I’d start there. Good luck!!!
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 01-11-2021, 08:39 AM   #5
Markoz28
Drives: 18 ZL1 nightfall grey A10
My car was misfiring too. Turns out that the plugs fouled out. They were gapped way too tight and I was not driving it hard. Changed plugs and gapped them at 32. Car drives great with smooth idle, as smooth as can be with a cam.
Markoz28 is offline   Reply With Quote
Old 01-11-2021, 11:16 PM   #6
JustDo1nMe
Drives: 2018 ZL1
Thank you guys ill try the above!
Old 01-12-2021, 12:56 PM   #7
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Are you running a tune with E85 or straight pump gas?
SFV1LE is offline   Reply With Quote
Old 01-16-2021, 02:35 AM   #8
JustDo1nMe
Drives: 2018 ZL1
Tuned on pump gas
Old 01-16-2021, 08:09 AM   #9
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
lots of bad spark plugs so start with that first...swap plugs then see if the misfire moves to the other cylinder
Old 01-16-2021, 03:38 PM   #10
Alain
Alain's Avatar
any updates on this?
2018 ZL1 1LE/Red hot
Old 01-16-2021, 06:03 PM   #11
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
MISFIRE
A bad valve spring will cause an misfire. I know I have my SS over at the dealer NOW, and that was their diagnosis. The car also would give me a service stabilitrak error as well which would clear temporarily when you restarted the car. The MISS was most noticeable at idle. I was told by GM tech that GM had gotten a bad batch of valve springs and that they were going to replace them all just to be on the safe side. Had that spring BROKEN and the valve dropped, then that would have been BYE BYE motor. That's why it is so important that when you get a FLASHING engine light that you immediately get it looked at.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 01-17-2021, 12:43 AM   #12
JustDo1nMe
Drives: 2018 ZL1
Not yet. I will keep this thread updated when I do.
Old 03-30-2021, 02:12 PM   #13
JustDo1nMe
Drives: 2018 ZL1
Hey guys just an update on this... I recently just got the car out of winter storage and did the mentioned triage steps.
Coil packs and connections seem fine but I pulled the OEM plug and it appears it might be fouled.
What do y’all recommend for replacement plugs and gaps on them for my setup?
Old 03-30-2021, 02:28 PM   #14
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Guys, crazy coincidence. Exact same problem with my 2018 this week. I tested coils and wires; all good. Thought for sure it was an Injector. I moved the plug to another cylinder and the problem followed it. Replaced the plug and good as new.
