#15 | |
![]() Drives: 2016 1SS (12/10/2016) Join Date: Jul 2015
If there was, I wasn't notified of an official recall. Maybe a TSB? If anyone finds a document on that, please post it here! |
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
there was the fan plug (you would see corrosion on the contacts or signs of melting if it had the issue) recall and there was the rear seatbelt thing. The fan thing was definitely a recall as I got a notice in the mail for that one ...never did it though because mine's fine. and nobody has ever sat in the rear of my car and likely never will. (might not be something that ever impacted the SS's - or didn't warrant a recall for them) https://www.camaro6.com/forums/showthread.php?t=461953 |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
Wasn’t this TSB for LGX?
#18 |
#19 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
Unfortunately it looks like you can add me to the list of having a fan go out. Noticed the other day my ac cutting in and out and I can watch the compressor cut on and off with just a little wiggle from the fan but never actually manages to start up. What's weird is that my car has not overheated and it's already in the mid 90s here in Texas.
#20 |
Drives: Chevrolet Join Date: Apr 2021
Is this just a 2016 SS issue? Mine is a 2017 SS...is I is, or is I ain't safe?
#21 |
Seems like it can happen to anyone. I'm definitely not impressed with any of the electronics on this car. I've had to change temp sensors door actuators and now a cooling fan on a car with only 15k miles.
#22 |
Moderator
Same here...
#23 |
#24 |
#25 |
Just a heads up for anybody doing this theirself the only hose you really need to remove is the small bottom one on the passenger side. With that hose removed it gives you enough room you can walk the fan side to side and straight out the top. Just be ready to have a pan underneath the car because quite a bit of coolant will come out if your not ready for it. Other than that it's pretty straight forward and doesn't really take any special tools to change it out.
#26 | |
D3RPZILLA
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy YouTube Playlists: Performance Mods | Show Mods | Other Mods ![]() |
#27 |
That would help but it's not the hose you have to worry about really its the barb that comes out the radiator housing. The hose you can bend up and out of the way. I ended up using a vacuum cap backwards and stuck it halfway inside that barb and it stopped leaking.
#28 | |
![]() Drives: 2016 Mosaic Black Metallic 2SS Join Date: Jan 2019
