Old 05-28-2020, 08:55 AM   #1
2006 owner
Drives: Camero 2SS
Radiator Fan Replacement
Does anyone have any info on how to change a Radiator fan assembly on a 2016 2 SS. It is so different from the Gen 5's. Can't seem to find any videos or info on this procedure. I see two push pin tabs on the bottom of the new AC Delco fan assembly. Do you have to remove a hose on the drivers side just to pull fan assembly up. Do you have to remove the splash guard on the bottom of car ? Any info will be appreciated.
2006 owner is offline   Reply With Quote
Old 06-02-2021, 09:18 PM   #2
Danny80027
Danny80027's Avatar
radiator fan assembly swap help
same issue, reaching back to see if others have replaced
Danny80027 is offline   Reply With Quote
Old 06-03-2021, 02:15 AM   #3
Monroe
Drives: Chevrolet
Are fans breaking on thee cars?
Monroe is offline   Reply With Quote
Old 06-03-2021, 08:22 AM   #4
cam765
Drives: 2019 SS
1. Remove air cleaner assembly
2. Remove radiator inlet hose (from top of radiator)
3. Remove transmission fluid cooler inlet and outlet pipe (from radiator)
4. Remove 2 fan shroud bolts (top backside of fan)
5. Unclip the aux radiator inlet hose from fan (2 push fasteners)
6. Unclip radiator outlet hose from fan (1 push fastener)
7. Disconnect electrical connector
8. Remove 3 push pins (going into top of fan shroud)
9. Remove aux radiator inlet hose
10. Remove 3 fan shroud bolts (bottom backside of fan)
11. Unclip the transmission inlet and outlet pipe from fan shroud
12. Remove fan
As always, you may be able to get away with less steps, if you're able to reposition hoses out of the way instead of completely removing them.
cam765 is offline   Reply With Quote
Old 06-03-2021, 12:43 PM   #5
zirad54
zirad54's Avatar
Drives: 2017 Camaro 2SS, MRC, NPP,
yes. I used my extended warranty for this (over 1k$) and this alone paid for the extended warranty.
zirad54 is offline   Reply With Quote
Old 06-03-2021, 01:12 PM   #6
Monroe
Drives: Chevrolet
Motors failing?...Whats the issue with them? How many miles before breaking.
Old 06-03-2021, 07:47 PM   #7
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
First I've heard of it, I wouldn't sweat it the internet magnifies everything.
Warrior102 is offline   Reply With Quote
Old 06-05-2021, 11:31 AM   #8
DetCam
DetCam's Avatar
Drives: 2016 1SS (12/10/2016)
Order the part on Rockauto (half the price the dealer charges), take the car and the part to the dealer and pick it up in a few hours. 2016 1SS... fan went out right after warranty expired.
Granted, I have a dealer 30 mins away that I actually trust... (I drive right past two other chevy dealers on my way there). They won't "Warranty the part" if I bring it in from outside, but I don't mind.
DetCam is offline   Reply With Quote
Old 06-06-2021, 01:17 AM   #9
Monroe
Drives: Chevrolet
Whats the issue?
Old 06-06-2021, 10:18 AM   #10
DetCam
DetCam's Avatar
Whats the issue?
Radiator Fan doesn't turn on, and the car will run hot or overheat. (Coolant temp will climb, and you'll get a notification on dash that it's too hot...)
This happened to me on a cool 50 degree day, but I was iddling in one place for over 20 mins. That was long enough that it wanted to run the fan to cool it off. Luckily, I was able to "Get out of line" and go drive at normal speed as soon as the warning popped up and the temps dropped to normal immediately.
You (typically) need to replace the whole assembly. GM Part number 23332215.
It's a large part, comes in a 32" x 30" x 5" box.
Old 06-06-2021, 06:14 PM   #11
Monroe
Drives: Chevrolet
How many miles before failure?
Old 06-06-2021, 09:37 PM   #12
Trochoidal
Drives: 2017 Camaro 2SS A8
Looks like cam765 has you covered.
New part# GM 84790788 for those interested.
https://www.tascaparts.com/oem-parts...ODQxMDAxMjg%3D
Old 06-08-2021, 04:00 PM   #13
DetCam
DetCam's Avatar
In my case about 42,000.
Old 06-08-2021, 04:13 PM   #14
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
didn't 2016's have a recall back in the day about the radiator fan connector allowing water to leak in when being washed or in heavy rain and this corrodes/shorts out the connector causing this problem?
