#15 |
![]() Drives: 2020 ZL1 Join Date: Dec 2019
You’re correct, that’s what I was considering race gas although maybe that’s not the correct terminology for the 100 octane. I do want to try a tank worth to see how much difference there is but I’ll probably wait till it’s warmer to get the full effect. Can I just run a full tank of it or should it be mixed 50/50 or something?
#16 |
I use an octane booster (RaceGas) with my supercharged SS that has similar power to a stock ZL1. Gas sold here, although 93 octane, still isn't good enough to run without knock retard at WOT, I typically add just enough to raise it to 95-96 and that cleans it up completely. Anything lower than 93 must be even worse for performance.
That said, I try to be conservative with this, not being an expert and having read some caveats about MMT (methylcyclopentadienyl manganese tricarbonyl) that is in these boosters.
#17 | |
![]() Drives: 2017 Camaro ZL1, 6M Join Date: Dec 2019
http://www.bazellracefuels.com/Calcs/OC1.htm |
#18 |
![]() Drives: '17 ZL1 Join Date: Jan 2018
You can get AVGAS (100-116 Octane) at small local airports too.
#19 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
#20 |
![]() Drives: Chevy Camaro Join Date: Jul 2019
Take your panties off and drive the friggen thing.
#21 |
![]() Drives: 18 Tahoe RST, 19 Z06 Join Date: Apr 2017
It will run fine on 91. Altitude means less dense air, less cylinder pressure, and less max boost.
If you have E85 on the Western slope that could be an option as well if you add the sensor and get a tune. E85 is easy to get in the Colorado Springs area so it is what I run mine on. |
#22 |
![]() Drives: 2017 Camaro 2SS Join Date: Mar 2019
With your altitude, 91 is pretty much 93. I lived in New Mexico at anywhere from 5000-6000 feet altitude at all times, drove a Terminator Cobra with 20 lbs of boost and used 91 octane daily with zero problems...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon |
#23 |
![]() Drives: 2001 corvette Z06. 2018 ZL1 Join Date: Jan 2018
#24 | |
![]() Drives: fast ones! Join Date: Jun 2019
check out the calculator in this thread...that'll help you figure out how to mix it to get the octane you want. It shouldn't hurt anything to run with a higher octane, but in "general" the wisdom is anything more than you need to avoid detonation is wasting money. And maybe even a tiny amount of power, as the higher octane number means it's harder to ignite the fuel, and you may not get as much fuel burn during the ignition phase. I'd probably just run 1 gal of 100 for every 2 gal of 91, as there's no guarantee the pump rating is accurate. |
#25 |
2020 Shadow Gray 2SS
They do, it's $7.99/gal!
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#26 |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
You are fine running 91 octane. Living out west I have done plenty of track days on 91. If the car is stock it will make all the timing adjustments and drive just fine.
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
#27 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Run 4oz of Boostane per fill up. 1 can should last about 8 fills.
#28 | ||
It's extremely unlikely that product documentation pages are wrong and the infinitesimal octane increase you claim to be all that's possible with these products would still have eliminated knock for me.
