Old 02-25-2020, 09:12 PM   #1
dbvettez06
Drives: 2001 corvette Z06. 2018 ZL1
Gas problem. No 93 octane
The highest octane available in western Colorado is 91. I’m at 4500 feet elevation. Looking for a safe solution to maximize the performance in the Z.
dbvettez06 is offline   Reply With Quote
Old 02-25-2020, 09:15 PM   #2
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Best option is buying a large amount of 110 octane race fuel or similar and supplement at fill ups to bring Octane to the 93-95 range. Second best is adding an octane booster at fill ups; the wars on which brand is the best rage on and on. Lastly, the car can function at 91, just not at peak performance levels.
Old 02-25-2020, 09:21 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Can you run E85? Superior to 93 anyway.
Old 02-26-2020, 09:04 AM   #4
IneedAZ
IneedAZ's Avatar
Is this a DD or weekend toy? If a weekend toy i would order a 5gal of Boostane next time they run a 15% or 20% off with free shipping. That brings the cost to around $8.50 per can and you can play with the mixture. That is what i run. I typically run 8-12oz each time, but i am starting with 93. I use just enough to hopefully keep the KR out. The 5gal will last me a year.
Old 02-26-2020, 09:08 AM   #5
Snowwolfe
Drives: CTV5 V Blackwing on order
I wouldn’t worry about it. Drove my 2013 C7 with an A&A super charger for 3 years while we lived in Colorado Springs with no ill effects. Your going to lose about 3% of your HP for every 1,000 feet in elevation and not much you can do about it. You can’t change the density of the air
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 02-26-2020, 09:14 AM   #6
Robster
Robster's Avatar
Drives: 2017 Camaro ZL1, 6M
I've got a similar issue in California, only 91 pump available. Luckily there a few gas stations nearby that sell 100 octane race gas at the pump (and others that sell 5 gallon pails).
5 gallons of 100 octane with the balance of the tank holding 91 octane averages out to about 93 to 94 octane.
I haven't dyno'ed the car to confirm but there's a noticeable seat of the pants drop in power when I refuel with straight 91 and the car does feel smoother and has less of a bog effect launching when running above 93 octane.
Robster is offline   Reply With Quote
Old 02-26-2020, 09:17 AM   #7
Juiced1
Drives: 2012 2SS CAMARO 45th
Meth is a good option. It is a instant octane adder and will cool intake temps. Win win on an LT4. We deal with Alkycontrol and Snow kits.
Juiced1 is offline   Reply With Quote
Old 02-26-2020, 09:29 AM   #8
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
http://race-gas.com/
Old 02-26-2020, 09:33 AM   #9
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I would use the 91 octane and buy a bottle of Octane Boost from Advance Auto, Autozone or any parts store and call it a day!
Old 02-26-2020, 10:15 AM   #10
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
93 isn't available in CO because supposedly 91 performs about the same at altitude, while not ideal it's not as bad as running 91 at sea level.
I haven't tried adding some 100 octane yet, but I plan on it...
Also, AFAIK Octane booster might only increase octane by a tiny amount, adding a can to 91 might not even get it to 91.5.
Old 02-26-2020, 10:21 AM   #11
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
I am in Colorado Springs and run 91 without issue
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 02-26-2020, 11:40 AM   #12
Oil Man
Oil Man's Avatar
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2)
This.
I've noticed when traveling through Colorado that gasoline sold at altitude runs lower octanes (regular unleaded is 85 octane in places) and the reason is air density at altitude. Running 91 will have the same net effect on your car at altitude that 93 would have at or near sea level.
Oil Man is offline   Reply With Quote
Old 02-26-2020, 12:41 PM   #13
VegasZ
Drives: 2020 ZL1
I I’m vegas and we only have 91 also. You can tell it’s pulling timing even stock and it’s not even hot out yet. It seems like the only non warranty killing option is to run a bit of race gas mixed in but that seems like a hassle for daily driving.
VegasZ is offline   Reply With Quote
Old 02-26-2020, 12:54 PM   #14
gd-bh
Drives: fast ones!
You may want to check out some rebel stations....I've seen some that have 100 octane at the pump.
gd-bh is offline   Reply With Quote
