#15 | |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
Good news - GM replaced his engine. |
#16 | |
#17 | |
NOXQCES ZL1
http://www.stahlbus.com/products/en/...alve/index.php |
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
No it's not. Only required for the ZL1 1LE. 15w-50 is only suggested if you can't get the dexos2 oil. LS/LT 1LE, SS 1LE, and ZL1 Change the engine oil to 0W-40 or 5W-40 that meets the dexos2 specification. If this oil is not available, the following oils can be used as an alternative: Valvoline SYNPOWER MST 5W-40 or Mobil1 15W-50. If 15W-50 is used, the engine oil must be changed after the track event. For LS/LT 1LE, add 0.9 L (1.0 qt) of oil over the nominal fill level for a track event. After the competitive driving, remove the excess oil so that the level on the dipstick is not above the upper mark that shows the proper operating range. During track usage, do not follow the Engine Oil Life System status.Change the engine oil after four hours of accumulative track usage. If 15W-50 oil is used, it must be changed back to the engine oil isted in the“Engine Oil”section oft he owner’s manual. ZL1 1LE Only Change the engine oil to Mobil1 15W-50. Change the engine oil after four hours of accumulative track usage. After track usage, the oil must be changed back to the engine oil listed in the “Engine Oil” section of the owner’s manual.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#19 | |
![]() Drives: DZ Join Date: Aug 2018
Nowadays these bearings are bi-metal (aluminum bronze) which are substantially harder than try-metal style bearings. I honestly think one could run a bottom basement synthetic oil of pretty much any brand and it will have good life. If you run a Dexos oil all will be ok - I would consider something with more film strength if running road coarse events or boosted applications (I use 10-40 Mobil 1) |
#20 | |
NOXQCES ZL1
#21 | |
Logic tells me the difference is intention. GM assumes a ZL1 will be driven differently than a ZL1 1LE over it’s life span.
2017 HBM SS 1LE
