Old 04-07-2019, 03:53 PM   #15
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Originally Posted by kmccall1978 View Post
Has someone measured stock intake then measured the CAI intake on the same day same dyno stock tune? Changed tunes and measured again. I would like to see if anyone has some testing to backup the claim that they rob power, and i mean good data and documentation. What situation do they rob power, is it defined and repeatable?
So it's just a whim that some refuse to tune one? They just made sh*t up?
When it's your livelihood to know what works and what doesn't you figure it out pretty quick.
Tuners are a community. They talk and share findings. Shops talk and share.
I don't think someone has saved and documented all the data just to appease a web forum crowd.
Old 04-07-2019, 04:14 PM   #16
Subcool
Drives: 2022 SS 1LE
I put the gm cold air intake on my 17 1le with their time and had a before and after dyno done . Not same day but it was same temps. I actually lost power after the install and gm tune. I posted the dyno results in a thread in the 1 le section a little over a year ago before I sold the car.
Subcool is offline   Reply With Quote
Old 04-07-2019, 06:40 PM   #17
appleman22
Drives: 2017 1ss 1le
This is the dyno sheet that subcool was talking about
appleman22 is offline   Reply With Quote
Old 04-08-2019, 01:19 PM   #18
TRich2SS
Drives: 2016 Camaro 2SS Summit White
I have this intake and it has given me nothing but problems since I have had it. From fitment issues, to high IAT's making me have to wrap it in ugly heat shield, to weird variations in my MAF readings. Pray actually did tune my car with this intake in it over 2 years ago now (he probably forgot) and he got it as stable as possible.
TRich2SS is offline   Reply With Quote
Old 04-08-2019, 07:24 PM   #19
jeep_junkie
Drives: 2000 Trans Am M6
I believe that I recall that you are/were working on a ram air duct system.
Any updates or info are appreciated. Thanks in advance.
I wouldn't put much stock in ram air induction. It was all the rage back when I had a third gen IROC and it actually helped those cars because the stock airbox was crap. The downside was the amount of crap the air filters collected off the road. Even on 4th gen TAs, an aftermarket lid makes about the same improvement as a ram air intake, and that's mainly due to a less restrictive design, not because of any "ram" effect. Still, I suppose it gives the aftermarket something to sell and the enthusiast something to tinker with.
2018 - 1SS - 1LE - Red Hot
jeep_junkie is offline   Reply With Quote
Old 04-08-2019, 08:07 PM   #20
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Smooth, unobstructed cool air has amazing performance benefits, especially in forced induction.
The intake cover behind the grill (though it was likely designed as you mentioned, to prevent water and material intrusion) is incredibly restrictive. My Z is not a DD and rarely (if ever) sees the rain. I don't mind cleaning my filter element more frequently for the performance gain of feeding my LT4 cool and smooth flowing air.
If you are interested there was a previous thread on this subject with some great photos from member Mountain.
https://www.camaro6.com/forums/showthread.php?t=548369
2018 ZL1 1LE sw/PDR
Old 04-08-2019, 08:58 PM   #21
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Originally Posted by RCF View Post
Same as before CAI and tune (assume you mean the GM “tune” that just recalibrated the MAF table?)?
you are correct. Also seeing faster lap times at the same tracks, but lots of variable besides the CAI
Old 04-11-2019, 05:56 PM   #22
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I put a Cold Air Inductions system on my 2016 SS and it really helped. Seemed like it picked up a little hp and ran better too but it was on the stock tune. I left it on the SS when I traded to get my ‘17 ZL1 last month. Can’t decide if I’m going to get a CAI for the Z now and whether a Cold Air Inductions or Roto-fab system and not in a rush to buy.
Old 04-11-2019, 08:48 PM   #23
revhead60
revhead60's Avatar
Drives: 2018 1SS Auto Mosaic Black Metalic
I put a cold Air Inductions on my 2018 SS and I had to recalibrate the MAF sensor because it was causing my Active Fuel Management to quit working and throwing a p3400 code. I fixed mine with HP tuners there's a video on YouTube how to recalibrate your MAF sensor using HPTuners.
revhead60 is offline   Reply With Quote
Old 04-11-2019, 10:00 PM   #24
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
did you line up the dots on the intake tube and box? iv never got any codes and you shouldnt. maybe you have a leak?
Old 04-16-2019, 06:04 PM   #25
revhead60
revhead60's Avatar
tube and box are installed right, double and triple checked everything even took battery cable back off to reset ecm still came on. put stock intake back on and had no problems. Put CAI back on recalibrated maf and its been working fine. No more codes.
