#15 | |
![]() ![]() ![]() Drives: ZL1 1LE A10 Join Date: Mar 2015
I have the same tick/habit and also inherited it from my old man ![]() The 1-2-1 trick is sure to fix the issue unless there's an actual mechanical fault.
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
#16 |
Another tick/habit I can't break is the need to wiggle the stick right-left-right-left-right-left and I do this obsessively when going into neutral.
OCD? Like however many times you think is a normal amount of wiggling to check if you're in neutral, I do it 3x more than that ![]() Like literally a good solid one-onethousand-two-onethousand-three-onethousand of wiggling haha. And another off topic MT tip: Don't rest your hand on the stick unless you want to wear out your selector fork.
