Old 08-03-2018, 09:48 AM   #15
Matt@Tick
Matt@Tick's Avatar
Drives: All GM Performance
Originally Posted by F1FTY View Post
Has anyone looked to see if this would work on the LT4?
I have a buddy with an LT4 Vette that I've asked to bring into the shop so I can figure it out. But it's been raining for over a week straight here and he doesn't want to get it out yet.
I feel like it will be the same as the LT1. The blower inlet will need to be ported for it to work.
Matt@Tick is offline   Reply With Quote
Old 08-03-2018, 09:52 AM   #16
F1FTY
Drives: 2018 ZL1
Excellent, looking forward to your findings. I know this is the LT1 subforum, but the ZR1 TB hadn't been mentioned anywhere else yet.
F1FTY is offline   Reply With Quote
Old 08-03-2018, 10:40 AM   #17
Matt@Tick
Matt@Tick's Avatar
I've been on Facebook with it on a personal level. People seem to overlook it tho. Everyone on Facebook seems to take a "Follow the Leader" notion and that makes others get overlooked. We have done tons of dyno testing on all the bolt-ons one by one, and some of the results I see others posting is comical really. The biggest gains to be had were from the MSD and this TB on our test cars.
Old 08-03-2018, 10:53 AM   #18
PRAY
PRAY's Avatar
Drives: 2016 2SS
I mentioned it on FB the other day after my initial dyno testing was done. Matt/Joey posted their results the other day but not as a straight TB comparison. The good thing is that our dyno results back each others up. I wouldn't have messed with it had they not told me about it for that it needed to be modified to fit. I will mention more once the track testing is done as well. The dyno is just a tool and the track really proves what works and what doesn't. So I would be leery of companies that only rely on dyno tests to prove out products. Products need to be tested and proven in both environments to validate their worth.
That being said, I will also be testing the 95mm on one of my FBO cars at the dyno and at the track. One test will be on the ported stock IM/TB and the other on a ported MSD. I am not sure we will see any tangible gains with a stock ported IM. Even with an adapter or the manifold throat opened up to accommodate the 95mm I am not sure I can get the interior of the stock IM large enough to make it worth it. Any restriction smaller than 95mm is still a restriction. On the ported MSD it will be a toss up. An engine can't use air it doesn't need. As usual, if it pans out to not be productive or worth the cost, I will post up honest and unbiased results.
Old 08-04-2018, 07:59 AM   #19
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
Would this work with a G1pro LTx Street Sheet Metal intake? Would it also fit with the nitrous outlet plate system?
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 08-04-2018, 03:20 PM   #20
PRAY
PRAY's Avatar
Drives: 2016 2SS
No idea about the plate.
Once the bolt holes are modified it should bolt up to anything the stocker does as long as the mani hole is big enough.
Old 09-11-2018, 12:38 AM   #21
Nitefall17
Drives: Camaro 1SS A8 Vert
Pray,
Any word on the ported stock IM and 95mm TB???
Nitefall17 is offline   Reply With Quote
Old 09-11-2018, 04:00 AM   #22
PRAY
PRAY's Avatar
Drives: 2016 2SS
It works but I have to port the crap out of the snout of your IM. I have two running now.
Old 09-11-2018, 08:23 AM   #23
Nitefall17
Pray,
Do you think it will change any values on shift points on an A8 and affect aggressive shift mode when you burp throttle......
Old 09-11-2018, 12:00 PM   #24
PRAY
PRAY's Avatar
Drives: 2016 2SS
Originally Posted by Nitefall17 View Post
Pray,
It may but I haven't had to make any adjustments to the cars I have put them on. But those cars are already tuned.
Old 09-11-2018, 12:03 PM   #25
PRAY
PRAY's Avatar
Drives: 2016 2SS
Originally Posted by onebad1le View Post
Yes.it works on lt4. I have some for sale adapter plates ( Bolton ) and throttle body
No drilling or anything
Package deal 350 for both shipped
So does your adapter address the restriction of the LT4 or stock IM opening? It seems to me that the 95mm TB would still be restricted by opening behind it with an adapter and then be of no worth in the end. Can you post some pics of the adapter?
Old 09-11-2018, 12:32 PM   #26
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’m guessing this is the adapter in question:
http://www.ictbillet.com/gen-5-lt5-9...or-lt4-sc.html
Old 09-11-2018, 12:57 PM   #27
PRAY
PRAY's Avatar
Drives: 2016 2SS
Thanks. So it appears it rotates the TB to make it work, not sure up or down but doesn't appear to solve the restriction issue.
Old 09-11-2018, 04:25 PM   #28
KonigWolf
Drives: 2016 2SS A8
I'd be interested in your adapter plate if I could get it in a custom thickness. Ex: Much thicker than the one ictbillet sells for 50.
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
