Old 04-30-2018, 10:00 AM   #15
slowlypullin
Drives: 2017 Camaro SS 1LE
Originally Posted by SSDan View Post
I know you had to fix it but I was kinda digging the idle sounds you had before.
I'm glad you found the problem and it was an easy fix.
It did sound good lol. Now I want a cam.
slowlypullin is offline   Reply With Quote
Old 04-30-2018, 10:54 AM   #16
TRich2SS
Drives: 2016 Camaro 2SS Summit White
I am about to go **** up my seal just so my car can sound like this
TRich2SS is offline   Reply With Quote
Old 04-30-2018, 09:14 PM   #17
Miami_1LE
Drives: 2018 Camaro SS 1LE
I was gonna say I think you have a leak. One time my intake filter came off the intake pipe and the car sounded super cammed because it was getting too much air.
Miami_1LE is offline   Reply With Quote
Old 04-30-2018, 11:57 PM   #18
vince3
Drives: 2022 Vivid Orange LT1-M6
I think I found the problem.
I have a MSD that has a slight idle issue and my car does backfire when I start it up. Can you help me out and give a good detailed explanation on how you fixed it? Mine could be leaking from the main gasket but i want to see first if i have the same leak as you.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 05-04-2018, 03:04 PM   #19
slowlypullin
It wasn't the MSD, it was the seal between the IM and the aluminum TB seal plate. Improper install caused the TB blade to pull on the seal causing a leak.
My check engine light turned on though, but I'm going to take it with my tuner.
Old 05-04-2018, 11:53 PM   #20
jhormilla
Drives: 2005 C6
LOL
jhormilla is offline   Reply With Quote
