Old 04-27-2018, 10:11 PM   #1
slowlypullin
Drives: 2017 Camaro SS 1LE
Rough Idle
Recently I installed a flex fuel kit and longtube headers (no cats). The car was running fine up after this mods. Last week I installed a ported MSD IM and it was running fine for a few days.
Today I went on a cruise and everything was fine. As I was driving home the car started idling rough on a stop. It sounds as if it had an aftermarket camshaft.
What do you guys think it could be? Can the MSD cause this?
Here is a video.
https://youtu.be/1UrDNKr2u1A
slowlypullin is offline   Reply With Quote
Old 04-27-2018, 10:22 PM   #2
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Did you remember to plug the map sensor in on the intake manifold? I didn't get mine tight once and it idled crappy
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 04-27-2018, 10:45 PM   #3
slowlypullin
All the connections are good. For running e85 it smells pretty bad and my tips are black like if its running rich.
Old 04-28-2018, 07:12 AM   #4
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Who’s doing your tuning?
blazzin1 is offline   Reply With Quote
Old 04-28-2018, 08:13 AM   #5
slowlypullin
Matt Sorian.
Old 04-28-2018, 09:23 AM   #6
blazzin1
blazzin1's Avatar
Matt Sorian.
I would discuss this with him! He’s a reputable tuner.... in some people’s eyes!
Old 04-28-2018, 12:45 PM   #7
vince3
Drives: 2022 Vivid Orange LT1-M6
Wow it does sound like a cam. Keep us updated.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 04-28-2018, 12:54 PM   #8
Spartan268
Spartan268's Avatar
Drives: HB 2SS
Double check the install for the MSD. Few times I've heard of members here who had similar idle issues with it after a few days because the bolts or something got very loose. Just needs to be re-torqued.
Or it could be the seal: https://www.camaro6.com/forums/showt...SD+idle&page=3
Spartan268 is offline   Reply With Quote
Old 04-28-2018, 05:26 PM   #9
slowlypullin
I think I found the problem.
Old 04-28-2018, 05:27 PM   #10
slowlypullin
Its the seal between the IM and TB
Old 04-30-2018, 01:55 AM   #11
vince3
what are we looking at?
Old 04-30-2018, 07:35 AM   #12
6spdhyperblue
Drives: 2SS 1LE
Those are tough sometimes
Old 04-30-2018, 09:11 AM   #13
slowlypullin
Its the seal between the IM and the aluminum TB seal plate. I fixed it and the car is running fine now.
Old 04-30-2018, 09:17 AM   #14
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I know you had to fix it but I was kinda digging the idle sounds you had before.
I'm glad you found the problem and it was an easy fix.
476 rwhp/440 rwtq (sold)
