Old 03-21-2018, 10:52 AM   #15
VinceK
Drives: 2019 6.2L V8 SS
Originally Posted by Jason@JacFab View Post
I don't see anywhere where you mention, or show pics of your car... Do you have the 18" wheels, or the 20" wheels? If you have the 20" wheels, they are pretty heavy. When I had the 20"s on my car, I would get like zero spin, despite on how high of an rpm I launched the car. Once I put some 18" wheels on (both with street tires, and my ghetto race tires), I could easily blow the tires off and had to actually try not to.
18" wheels sadly - build journal in signature with a few pictures, but it doesn't say wheel size on there.
VinceK is offline   Reply With Quote
Old 03-21-2018, 10:59 AM   #16
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I looked at the build journal, but couldn't tell what wheels you had from those pictures. Well that's not your problem then... That's really all I had.
Old 03-21-2018, 11:46 AM   #17
dekes1
Drives: Camaro like
I hate to beat the dead horse here, but it needs to be repeated over and over - tuning these later generation cars is not easy as many tuners think and can easily be messed up.
They operate on a very intricate torque modelling system that has numerous inputs and adjustments and if your tuner didn't modify all the interrelated tables appropriately, it could be incorrectly calculating torque and therefore cutting power.
We're you able to get wheelspin with the stock tune (doing the brake torque method)?
dekes1 is offline   Reply With Quote
Old 03-21-2018, 01:33 PM   #18
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Dunno i have the big heavy 20" wheels and i can easily break loose on the stock runflats and my less hard indy 500s if i want. I think his tune may be cutting torque or worse because i could chirp on the stock tune before bolt-ons as well.
Old 03-21-2018, 02:01 PM   #19
VinceK
I was definitely able to generate some by just flooring the gas pedal from a stop, let alone any sort of launching. All signs point to the tune at this point, and specifically the torque management aspects of it.
Working on having it tuned by someone else to get this issue resolved. If nothing else, I'll be sure to update again post-tune in case others experience my symptoms and are looking for some anecdotal experience on here.
Thanks everyone for your input.
Old 03-21-2018, 02:29 PM   #20
bodysnatcher
Bodysnatcher
bodysnatcher's Avatar
Drives: 2017 Black RS
I must have gottten a good RS with the 20's from Chevrolet, i can turn the I4 over at a dead stop with no problem, i hit it so hard one time that i blew a runflat out and had to get a new set.
bodysnatcher is offline   Reply With Quote
Old 03-21-2018, 03:30 PM   #21
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
The low gloss black 20x8.5's I put on mine were surprisingly light for a mass produced cast wheel. Weighed right at 29lbs. For comparison, I weighed a stock 18x8 GTO wheel we had laying around, and it weighed 28.5 lbs!! I bet the split spokes are just as light or lighter. My car is a mod free A8, and will light em up. Actually, the open diff surprised me because a few times I left 2 marks not just one. Hopefully you get it all worked out VinceK , keep us posted!
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 03-21-2018, 05:09 PM   #22
rickwelch69
rickwelch69's Avatar
Drives: 2016 1LT RS Turbo 4
while mine was in the shop (2016 rs m6) I was in 6 different loaners, all a8's. 4 17's and 2 18's, 3 were rs's and they would all light the tires wiyh no problem, all would get both wheels spinning also. all ranged in miles from 9 to 690, 2 months worth.
2016 2.0 RS::K&N drop-in filter::RPM Catless down pipe::RPM Tune::Mishimoto Hot&Cold side charge pipes::65ish mm throttle body::289rwhp/328lbft
rickwelch69 is offline   Reply With Quote
Old 03-21-2018, 09:11 PM   #23
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
THIS.
SO MUCH THIS.
This is what people do not understand regarding these ECU's. They think they can take them to Jackwagon Tuning LLC because they have a DYNO.
As more time passes, and more Camaros are pushed, the same old LTG problems will keep creeping up. I can't wait for the ringlands going bad, I think it might be my all time fave...
This is in no way a personal attack or confrontation, and is not necessarily the view
of the management or sponsors, and the thoughts contained herein are mine,
and is not intended to hurt anyone's feelings or ruin their delicate self esteem, or
to invalidate anyone's personal views or thoughts, nor is it a condemnation of anyone's
race, religion, sex, sexual preferences, handicaps, or intellectual abilities.
ChicagoTommy is offline   Reply With Quote
Old 03-21-2018, 09:30 PM   #24
ChicagoTommy
I have a guess, but is this tuned?
Old 03-21-2018, 09:45 PM   #25
Evil-Bee-NH
603 Camaros
Of course the only way we'll learn what to do and not to do is by trial and error no matter how good a tuner you get the engine despite being a new age version of older engines is still new despite being in the ATS for awhile. Even ZZP plays it safe with customer cars.
Old 03-23-2018, 12:21 PM   #26
VinceK
Will do - re-tune has been ordered through ZZP (as it should have been in the first place). Looking forward to wrapping this up.
Old 03-31-2018, 12:13 AM   #27
VinceK
Reporting back in on this - comes as no surprise that the tune was the culprit.
After ZZP's tuning the car went from 5.4-5.5 0-60s to under 5 (working on getting a good run with little slip, been driving a vehicle that essentially could not slip for so long).
Beyond this, startup used to be extremely loud and a bit rough, it now starts up much more quietly and smoothly. Throttle response is far better... just a different car in general.
Glad to have this corrected to say the least.
Old 03-31-2018, 06:31 AM   #28
Evil-Bee-NH
603 Camaros
Good to hear.
