Old 12-27-2017, 11:53 AM   #15
jamoka3
jamoka3's Avatar
Drives: 2018 Camaro SS (2SS, A8, NPP MRC)
This seems like a lot of button pushing going on...
Time for some of the drag strip guys to make a Youtube video "how too" for proper setup and launch techniques.
Ill be the first one to tell you, I have no clue on the "proper" way to stage my new Camaro, on stock run flats, at the track.
jamoka3 is offline   Reply With Quote
Old 12-28-2017, 09:46 AM   #16
51FIFFT
Drives: 2017 2SS M6 FIFTY @51fifft
Originally Posted by MP3BOOSTED View Post
So holding it down for 10 seconds to completely turn everything off in touring mode or pressing it once seems to work with being able to do a stand still burnout? Or brake stand burnout? I’m honestly at a loss as well coming from a M6 1LE and not being able to do a burnout.
If you just want to burnout then put the car in tour mode ( seems TM is not an issues here ) this is my experience. While in tour mode press the TC button 1 time ( traction control off ) do your burn out! If you want to get real shi**y hold the TC button until both lights come on ( traction control/stability control )
off and let her rip.
" All you have to do is press the button once to turn off traction control and leave stability control on. Nothing else needs to be done besides that. This is competition mode."
This is not competition mode.. You have to be in sport or track mode and double press the TC button and it will say competition mode active. Torque management plays a part in this and will restrict the tires from spinning.
So even with the car in track mode and TC off TM kicks in and keeps the car from spinning.
51FIFFT is offline   Reply With Quote
Old 12-28-2017, 09:58 AM   #17
51FIFFT
On the stock tires Launch control is worthless. Using launch control the best way i have found is "slipping the clutch" not side stepping. I'm not a pro drag racer but go out had have fun. My best is 12.3 with a 1.8 60" on street tires bone stock.
Best thing to do is go out and practice, have fun. My advise is don't worry about the light, time don't start until you break the beam. Work on your 60" get the launch figured out and the rest will fall into place.
for someone to tell someone how to launch their car is very hard due to how the track prep and many other factors to take into consideration. practice practice and most of all have fun!
Old 12-28-2017, 11:22 AM   #18
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
Thank you, definitely going to give it a try!
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 12-28-2017, 11:44 AM   #19
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
I'll try that too. When the weather warms up enough to drive it.
Magnum922 is offline   Reply With Quote
