Old 10-26-2017, 09:37 AM   #15
Electron Mike
Drives: 2018 ZL1
I have owned both the ZL1 1LE and now the standard ZL1. I'll echo the comments made here and add that unless it is a dedicated track car only with almost zero street duty, I personally prefer the standard ZL1.
The ride on the 1LE is frankly bonkers stiff for a street car, and even on smooth roads here in Austin very taxing. I'm a track rat too, and I still wouldn't go with the 1LE unless it was a dedicated track car... but then again if you are doing that there are better options (radical, wolf, formula mazda, etc.) A 300 mile trip in my ZL1 was no problem, but you couldn't pay me to drive a ZL1 1LE that far on the broken roads I drove on. My spine would be in a different location.
My .02 of course. I'm personally more impressed with the standard ZL1 as it is much more well rounded while still very fast.
Electron Mike is offline   Reply With Quote
Old 10-26-2017, 12:06 PM   #16
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by travislambert View Post
For some, the bolt-on approach would work just fine. For me, not so much.
When it comes to cars I have a little bit of OCD. Even with every 1LE bolt-on, it still won't be a ZL1 1LE because GM doesn't make the software available. So the PTM coefficients are going to be wrong, the speedometer is going to be off, etc. (Of course the speedometer can be corrected with a tune, but that'd void the powertrain warranty.) Not to mention some 1LE features like the transmission gearing and lighter weight rear glass aren't practical to swap. I'd also need painted parts like the reinforced '18 trunk lid and front fascia. I'm betting I'd always see a slight difference in the paint, which would drive me nuts.
In terms of dollars, swapping aero, tires, and wheels only would probably make sense if GM would offer the 1LE software. I'd seriously consider it, but I'd probably still prefer having a genuine 1LE.
Thanks again for your input. The wing blocking the driver's view behind the car is something I hadn't thought of. It's certainly good to know these things beforehand.
I understand completely.
(And I discovered the wing was at the perfect height - for where I sit - to block out tractor-trailer headlights at night! )
Old 10-26-2017, 01:21 PM   #17
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Whichever way you decide to go be sure to keep us updated on the eSLD wheel slip investigation.
Old 10-26-2017, 02:02 PM   #18
FringBirdAloha
Drives: Pre-production ZL1 M6
*I'd also need painted parts like the reinforced '18 trunk lid and front fascia. I'm betting I'd always see a slight difference in the paint, which would drive me nuts.*
Did we ever figure out if there is really any difference in trunk lids?
FringBirdAloha is offline   Reply With Quote
Old 10-26-2017, 04:01 PM   #19
travislambert
Drives: '17 ZL1
There is. GM actually published a bulletin about it.
#17-NA-310 - Information on ZL1 1LE High Wing Rear Spoiler Installed on non ZL1 1LE Models
Here's some text from the bulletin:
"The ZL1 1LE high wing rear spoiler uses the same mounting holes as vehicles equipped with a stanchion spoiler. Installation of the ZL1 1LE high wing rear spoiler requires internal reinforcement to the decklid due to the downforce the high wing provides. 2018 Camaro decklids are produced with the internal reinforcement. Addition of the ZL1 1LE high wing spoiler may cause the decklid to buckle on a 2016/2017 Camaro unless the decklid is replaced with a 2018 reinforced decklid."
travislambert is offline   Reply With Quote
Old 10-26-2017, 04:03 PM   #20
travislambert
Drives: '17 ZL1
I will.
Old 10-26-2017, 06:32 PM   #21
Studebakerpm
Drives: 2015 Chevy 3500, 53 Studebaker P/M
Just took delivery of my 2018 ZL1 1LE this past weekend. I had a 2017 ZL1 on order and missed the cut off. I only have a 150 miles on her and I couldn't be happier. The car is an animal. The ride is just fine for me. It's a toy and not a daily driver. I have an 09 Malibu for going back and forth to work. I think you would seriously enjoy everything about it. Good luck to you!
Studebakerpm is offline   Reply With Quote
Old 10-26-2017, 07:10 PM   #22
travislambert
Drives: '17 ZL1
Thank You!
Old 10-26-2017, 09:31 PM   #23
waterman
waterman's Avatar
Drives: Grandad's C2 L89
subscribed
Life is short Travis... Follow your heart.
Thanks for your work on ELSD.
2018 ZL1 1LE sw/PDR
Old 10-26-2017, 10:11 PM   #24
travislambert
Drives: '17 ZL1
Thank You.
My pleasure. I'll keep working the issue. I just sent another email to GM this evening in hopes of getting a status update.
Old 10-26-2017, 11:07 PM   #25
Fast Dalmation
Fast Dalmation's Avatar
Drives: 2018 Summit White ZL1 1LE
Hey Travis,
Live in MD, so if you need to feel the beast just send me a PM. Simply a perfect car
that is not from across the pond.
Have owned American and European autos, but this beast is special!
Cheers
Fast Dalmation is offline   Reply With Quote
Old 10-27-2017, 12:06 AM   #26
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Originally Posted by Stephen12ZL1 View Post
I suppose you mean Track mode and then PTM race. That mode(s) is way stiffer than Sport to me.
i think you are correct. I may be mixing it up with the GT350 I had
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 10-27-2017, 12:10 AM   #27
PinHead
Drives: Duramax
Originally Posted by nighttowl View Post
Do you ever set your mag ride to race and then think to yourself "the suspension is just way too soft on this car"? if so the 1LE may be the car for you.
GM should do you right and exchange it as you're the only one that has had the balls and tenacity to go up against them and solve the M6 Launch Limiter issue AND FIX IT.
If not, your wallet will bleed a little but LIKE THEY SAY;
PinHead is offline   Reply With Quote
Old 10-27-2017, 12:33 AM   #28
FringBirdAloha
Dang. Glad I saw this. Now I need to order a trunk lid. I certainly feel your pain. I really wish I had waited for the ZL1 1LE.
