Old 07-07-2017, 03:22 PM   #15
17_zl1
Drives: 17 ZL1
I chose to go with a 2.30 upper, i removed my blower separated the snout and sent the snout to vengeance racing where they installed the upper and sent me back my snout. I have rotofab cai, flex fuel sensor, 2.30 upper pulley, ported TB (waiting on it) and then I will take it to get tuned.
17_zl1 is offline   Reply With Quote
Old 07-07-2017, 03:55 PM   #16
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Who's doing the tuning?
Smart mild bolt ons, I'm looking forward to your results.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 07-07-2017, 04:04 PM   #17
17_zl1
Drives: 17 ZL1
vengeance they are a 6 hour drive from me ( and the most expensive by far that I've called) but I feel like I will get my monies worth that way.
Old 07-07-2017, 04:05 PM   #18
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Can the snout be removed without removing the blower?
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 07-07-2017, 04:19 PM   #19
Ron_Robinson1
These blowers are simple to remove compared to the LSA setup. Myself and a extra set of hands could lower the cradle and pull the LSA blower within 1.5 hours easily.
Old 07-07-2017, 04:33 PM   #20
17_zl1
Drives: 17 ZL1
Unfortunately no, but the blower is easy to remove, there is a a few things to be noted.
1. The IC cooling system is a closed circuit and can only be vacuum filled using a special fitting no other method will work. ( i took mine to the dealership after i put the car back together and had them bleed with distilled and water wetter)
2. You cannot re use any of the supercharger to head bolts as they are stretch bolts.( I broke one off, no one seems to want to tell you do not re use, several Z06 DIYs and shops said otherwise) The dealership should sell a "kit" for less than 200 including all new gaskets and bolts etc.
3. Make sure the surface between the snout and blower is thoroughly cleaned and you only use the AC Delco engine sealant
4. Ask the parts guy to nicely print you the SI procedures for the blower/ cover removal so that you have all torque specs.
Here is what I have spent
Pulley installed/Belt/sparkplugs/shipping to & from VR- $420
Cooling system bleed- $159
Gaskets and sealant- $149
Rotofab CAI- $506
Mamo TB- $375
DSX Flex fuel- $400
Tune- $1200
Old 07-07-2017, 04:55 PM   #21
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
Rotofab CAI- $506
Mamo TB- $375
DSX Flex fuel- $400
Tune- $1200
Going Fast - $PRICELESS
Rotofab CAI- $506
Mamo TB- $375
DSX Flex fuel- $400
Tune- $1200
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 07-07-2017, 04:55 PM   #22
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
That sucks. When bleeding is there not an electric water pump that turns on when holding down the push to start button for 10 seconds? My whipple has one which allows me to connect a fixed funnel to the filler tank. The system starts and purges it of air.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 07-07-2017, 05:02 PM   #23
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Rotofab CAI- $506
Mamo TB- $375
DSX Flex fuel- $400
Tune- $1200
Dam that tune sure does seem high. Can't wait to see the results
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 07-07-2017, 05:36 PM   #24
17_zl1
Drives: 17 ZL1
Yeah like I said they want substantially more than anywhere else in the vicinity. Peace of mind is priceless for me
Old 07-07-2017, 05:51 PM   #25
SS Camaro Freak
Drives: 2016 Gen 6 SS 6spd
On the new cars Credits are x 4 from HP tuners. That's $200 going to HP tuners. So V is only getting a $1k for tuning the car on 93 and E85 which takes double the time. That's actually cheap!
SS Camaro Freak is offline   Reply With Quote
Old 07-07-2017, 08:07 PM   #26
USP45
Sucks about the IC needing special parts to bleed... I am aboit to have to crack mine open as well.
USP45 is offline   Reply With Quote
Old 07-07-2017, 08:15 PM   #27
Rotofab CAI- $506
Mamo TB- $375
DSX Flex fuel- $400
Tune- $1200
DSX Flex Fuel is now $300
Absolutely... and HP Tuners wants double the credits $200 just to register the ECP and they don't let tuners buy the model years on these. It's car by car.
Old 07-08-2017, 12:57 PM   #28
Ehuerta
USN VET
Ehuerta's Avatar
Drives: 2016 SS sedan, 2018 ZL1 1LE
Originally Posted by Getinthur View Post
Has anyone upgraded their Pulley on the supercharger to get more boost? I'm struggling to find some options out there and curious to see what others have done.
Is this what you're looking for?
http://cordesracing.mybigcommerce.co...h-10-bolt-hub/
Ehuerta is offline   Reply With Quote
