Old 07-07-2017, 07:41 AM   #1
Getinthur
Drives: 2017 ZL1
Upgraded ZL1 Pulley
Has anyone upgraded their Pulley on the supercharger to get more boost? I'm struggling to find some options out there and curious to see what others have done.
Getinthur is offline   Reply With Quote
Old 07-07-2017, 08:30 AM   #2
MOSAIC BLACK 1LE
Drives: Mosaic Black ZL1 M6
I would like to know myself. Anyone?
MOSAIC BLACK 1LE is offline   Reply With Quote
Old 07-07-2017, 08:57 AM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
http://www.metcomotorsports.com/prod...p?prod=ICP-LT4
Old 07-07-2017, 09:23 AM   #4
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
My local shop that did my work did the below. Link to the work they performed.
Kooks, ATI 18%, RotoFAB and AEM Meth injection
Looking at their dyno it put down quite a bit of power under the curve.
https://www.flickr.com/photos/138619...h/35352502845/
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 07-07-2017, 09:58 AM   #5
Getinthur
Drives: 2017 ZL1
Sorry to sound dumb lol, was is ATI 18%?
Old 07-07-2017, 10:03 AM   #6
USP45
Drives: 2017 ZL1 A10
I am going with a 15% lower. From a lot of reading here and on the Z06 forums much over that and you are really working our 1.7 supercharger pretty hard and getting into overspinning territory. Also making a lot of heat so need either e85 or meth to be efficient. Really more of meth at that point to help bring temps down some.
Personally I am going to run e85. I see it as being a safer choice. With a flex fuel sensor, if you cannot find e85 you will revert to a 93 or 91 map. With meth if you run out you had better stay out of the upper load range. Sure the ECU is supposed to protect the engine, but running out of meth if your tune depends on it can be very risky. I saw a lot of Evo guys blow engines up by running out of meth or pump failure...
USP45 is offline   Reply With Quote
Old 07-07-2017, 10:04 AM   #7
USP45
Originally Posted by LiqTenExp View Post
You aren't using the stock LT4 blower, 18% is probably too much for IAT, 10% might be better on stock LT4 blower.
I think his link was for another persons ZL1, not his car with the Whipple...
Old 07-07-2017, 10:08 AM   #8
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Yep, deleted it after scrolling through the pictures of the build.
Old 07-07-2017, 10:10 AM   #9
Getinthur
Drives: 2017 ZL1
Does anyone have a link for the pulleys, the one above was for crank pulleys, not the same.
Old 07-07-2017, 11:06 AM   #10
Sftshldr
Beast Rider
Sftshldr's Avatar
Drives: 2017 ZL1 BLK A10
ATI Super Damper 18% Overdirve crank pulley and belt ring.
"Just looking fast is sometimes all it takes!!!"
Sftshldr is offline   Reply With Quote
Old 07-07-2017, 01:56 PM   #11
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Meth was not needed for that mod list....odd
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 07-07-2017, 02:05 PM   #12
Joe's_cool_1le
Meth to keep it cool.
Old 07-07-2017, 02:23 PM   #13
Ron_Robinson1
I have used meth for many years, I know what it can do. But if this is on a new ZL1, it's still not needed. Guys run this same simple bolt ons the C7 Z06 with out meth and the ZL1 has a 10 times better cooling system.
To eachs his own.
Old 07-07-2017, 02:32 PM   #14
Joe's_cool_1le
To eachs his own.
A lot of heat for that small blower but controlling heat can be subjective I guess.
