#15 |
![]() Drives: 2016 Camaro 2SS, 6spd M Join Date: Aug 2016
Groovy! Yeah, not sure. Next time I visit my dealership I'll ask for a quote through them just to compare.
#16 |
I'm afraid I did not look that closely. Nothing was touching and everything was clear, but by how much I didn't measure. I'll do that next time I mess around with them.
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS M6, NPP Join Date: Apr 2016
Here are my 315's.. I have Toyo R888's 315/30/20 and the tire is massive, almost 13" mounted. ![]() ![]()
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Looking at offsets (see post above) there should be more room vs stockers. But how much exactly I don't know.
#19 |
![]() Drives: '17 SS/1LE/PDR Join Date: Feb 2017
nice! that looks good, looks like a mini tubbed muscle car to me!
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
#20 |
What wheels are the 315s on and what size/offsets/camber pls?
#21 |
OP what's your present camber pls?
#22 |
thanks, much appreciated!
#23 |
#24 |
#25 |
Thx for the info. Very surprised that F 11 wheel would even fit with such offset. Expected the ET to be much less than stock 10 wheel to compensate never mind a greater value vs stock. Glad you made it all work tho!
#26 | |
With -2 camber, the wheel is slight tucked in the fender with a 43et... I'm going to do -1 camber since im not hitting the tracks any time.. any lower ET might have more poke.. The real question, will a 11.5 inch rim fit without having extreme wheel poke? Lol |
#27 |
You're running -2 camber on the R wheels?
Ya the R wheel is just like stock so no surprises here except for a wide tire needing more space, but I am REAL surprised seeing a larger ET on a 11 F wheel than the stocker 10. To fit properly (on the inside) it should be the reverse...but that would poke out obviously. |
#28 |
![]() ![]() ![]() ![]() ![]() Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
The rear offset is 26mm AFAIK.
