Old 04-30-2017, 07:26 PM   #15
gdgraph
gdgraph's Avatar
Not sure what the best way to secure it to the center console is, but maybe if you put a couple of dots of hot glue down (on the black part of the plastic only), you should be able to peel the hot glue off when you want to remove it.
You wouldn't be able to change the modes or use the ebrake, but maybe if you cut slits where the black marks are you'd be able to flip it up and use the buttons (assuming your dog's paws aren't small enough to push down on the hinge, and then just tack down the case to the console with hot glue where the white dots are. May also need to notch out the spots where the side of the case comes into contact with the raised portions of the silver plastic on the car so it can sit flat and flush for the hot glue to stick to the case. I don't think the hot glue gets hot enough to deform any of that black plastic, and when you want to remove it you can just peel it up.
gdgraph is offline   Reply With Quote
Old 03-27-2025, 01:00 AM   #16
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
Anyone ever come up with something?
I was thinking about looking into the wiring and maybe adding an on/off switch inline to disable each switch individually.
2018 Blue 1LE is offline   Reply With Quote
Old 03-27-2025, 05:26 AM   #17
Deacon Blues
Drives: 2024 Camaro 1SS M6
I thought it was on here, but maybe it was on the Camaro subreddit, but someone designed and 3d printed a cover for the TC/mode switch that flipped up as needed...
Deacon Blues is offline   Reply With Quote
Old 03-27-2025, 07:38 AM   #18
cdb95z28
cdb95z28's Avatar
https://followmyline-shop.fourthwall...cUrfZMYud6wyQA
"KEEP THE FAITH"-Fbodfather
cdb95z28 is online now   Reply With Quote
Old 03-27-2025, 09:21 AM   #19
2018 Blue 1LE
Thanks.
Old 03-27-2025, 02:21 PM   #20
roostere4
Drives: 1987 IROC, 2020 ZL1
Thanks for the link to that. My only question is has anyone used this in area where it gets hot in the summer? Wondering how it has held up.
According to Google. Theoretically a car in even in 80 degree Fahrenheit weather could approach 172 degrees Fahrenheit on the interior. Which is at 77 degrees Celsius seems to be at the higher end of the range where PLA which this is made out of will deform
roostere4 is offline   Reply With Quote
Old 03-27-2025, 03:12 PM   #21
calypso50kid
Drives: 2018 zle, 03 cobra, 92 mustang lx
sucks they are out of stock at the moment
Owner and driver of the worlds fastest naturally aspirated drag radial car. Hays Consulting and Performance
4.58@151 BBC powered 585 ci 9000+ rpm
https://youtu.be/wSz2OedlNSI?si=SnPoqreXFQ7NLYX8
2018 ZL1 1LE 416ci LME long block, 2650, reflex port injection, full e85, tick performance tr6060, monster triple disc, DSS drive shaft, g force axles.
calypso50kid is offline   Reply With Quote
Old 03-27-2025, 03:44 PM   #22
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
It says they are made to order.
NOTE: All Sales Are Final. This is made to order, and cannot be returned once your order has been placed.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 03-27-2025, 04:25 PM   #23
Deacon Blues
That's the one, thanks!
Old 03-27-2025, 08:14 PM   #24
Blackrat
Drives: 2021 ZLE & 1972 Camaro
I sent an email to them for clarification. There's no way to order the cover on the page. I tend to hit the buttons often if I'm wearing a coat.
Blackrat is offline   Reply With Quote
Old 03-27-2025, 08:50 PM   #25
SS_Don
SS_Don's Avatar
Let us know what you find out. Might be interested in one also.
Old 03-28-2025, 08:56 AM   #26
Deacon Blues
I'd definitely be in for one as well. I didn't think it would be a problem but I do tend to bump those buttons more often than I'd expect.
Old 03-28-2025, 09:04 AM   #27
2018 Blue 1LE
Old 03-28-2025, 11:04 AM   #28
Blackrat
Very quick response from them.
They are just out of stock. More are in production, and we should have more stock early to mid next week.
Thanks!
