Old 04-16-2017, 07:57 PM   #15
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 04-16-2017, 08:01 PM   #16
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
On a side note, I never have heard of this being a problem with LT4. I have been also watching the C7 Z06 forum and have never have heard of this issue.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 04-16-2017, 08:37 PM   #17
Sharp Shifter
Drives: 98 Transam drag car SOLD now 17 ZL1
Not at liberty to say lol i don't want it to become a thread for mocking or anything like that. Was just curious if this was something anyone else had heard about. Because i dont want to void warranty if this is a issue or if someone just messed up somehow.
Sold 780rwhp 840rwtq 98 Trans Am
Current car 2017 ZL1 Camaro
Sharp Shifter is offline   Reply With Quote
Old 04-16-2017, 08:39 PM   #18
Sharp Shifter
Ok awesome, thats the feedback i was looking for. I appreciate it man
Old 04-16-2017, 09:49 PM   #19
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by datboi448 View Post
not at a dealer for warranty work? speaks for itself it seems.
I tend to think the same....until I hear otherwise.
Old 04-16-2017, 10:29 PM   #20
This is most likely the one LT4 Z that blew up here a couple months ago.
It was modded to the hilt and I believe he's going back twin turbo now.
Old 04-17-2017, 04:05 AM   #21
crunch527
Drives: Big Brown
I figure anyone who has the money to buy a new ZL1, mod it, and not give a shit about the warranty, can afford to fix it when/if it blows up. So in total, its really a non-issue.
Besides, a replacement (crate version) of the LT4 can be had for about $16K...maybe have a shop strengthen the bottom end and let her rip!
crunch527 is offline   Reply With Quote
Old 04-17-2017, 05:53 AM   #22
Ipockalypse
Ipockalypse's Avatar
Drives: 2017 ZL1 M6
Originally Posted by Boilermaker128 View Post
Oh wow a whole 3,000miles...
Not that it's necessarily a lot in the big scheme of things but considering the ZL1 LT4 hasn't been out long...I'd say that's probably a descent amount of mileage so far.
Ipockalypse is offline   Reply With Quote
Old 04-17-2017, 06:58 AM   #23
7WSM
7WSM's Avatar
Drives: 2017 ZL1 A10
In stock, did you mean Houston Stock? Or Stock from the factory? Either way, something just seems fishy around here. I have seen plenty of modded LT4s in for repair and I have never heard of anything like this before. Most of us are going to raise the BS flag without knowing any specifics.
7WSM is offline   Reply With Quote
Old 04-17-2017, 08:01 AM   #24
Sharp Shifter
ya but the tubes are located at the bottom if im not mistaken, and the biggest build zl1 right now are cam only cars. Now you do have to pull the oil pan off to get the timing cover off and such but wouldn't imagine hitting those tubes but maybe that's what happened. Because a tune, meth ect is not going to move those if the bottom end hasn't been messed with.
but again, I've personally assembled LS motors several times and have never messed with an LT so I do not have a clue because I've been out of the game for a few years. I know there are people way more fresh on it than I am besides obviously the forum sponsors who build these cars weekly lol
just thought this was a good thread to start since in some way or another it did happen and wanted to see if anyone else had heard of this.
Old 04-17-2017, 09:07 AM   #25
aka Reckless
aka Reckless's Avatar
Drives: 2016 2SS Camaro
That looks like a cast piston? Aren't the LT4 pistons forged?
aka Reckless is offline   Reply With Quote
Old 04-17-2017, 10:27 AM   #26
Ron_Robinson1
Your dead on.. I think the biggest ZL1 built right now was all bolt ons, Meth, e85, and Cam. So no reason at all should the engine be pulled for that, let alone have anything to do with the oil squirters.
So does this worry me, absolutely because I will be modding my car like the mods listed above. But again I have never seen a problem like this before with the LT4 (well at least not in the Z06s), so was it just a fluke (expensive fluke) or will we be seeing more of these issues.
Old 04-17-2017, 10:30 AM   #27
Ron_Robinson1
Pulled from the GM site: Forged aluminum pistons with flat top crown that supports the 10.1 compression ratio and internal ribs for strength (similar to the LS9 piston design). A premium ring pack includes a PVD-coated top ring, chrome-coated second compression ring and a nitrided oil control ring – all for exceptional wear resistance and durability under high cylinder pressure. The bottom ring land also features eight oil drains
Old 04-17-2017, 10:44 AM   #28
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
A shop in houston had a stock car come in with some issues (think it was a zl1) and took apart the motor and found a huge chunk of the skirt of the piston broke off and 2 others cracked. Diagnoses, three of the oil squirt tubes were lower than the others and were nipping the pistons...... ill add photos in a second, but apparently this is not the first case of the lt4s having this issue..... anyone else hear about this??
Stock...I don't think that was a stock car otherwise it would've gone to a dealership for service/repair....the shop is dealing in alternative facts here
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
