Old 04-19-2017, 09:01 AM   #15
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Originally Posted by RobsCountach View Post
Thanks !
I have an email into them, but not heard back. Hopefully, he will respond or I'll find him.
Probably want the version, where I can change back to stock, in case of a service visit...
His name on here is psykostevo. Here is a thread he started.
http://www.camaro6.com/forums/showthread.php?t=490880
I'm sorry to say, once you get tuned you cannot hide it. If for some reasom GM looks for this they can tell. Just want you to be aware.
Old 04-19-2017, 09:43 AM   #16
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
You could swap in a stock computer... But, not sure if they could also tell this (encoded to the car maybe?)
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 04-19-2017, 09:58 AM   #17
Michigan1LTRS
Blessed ❤️
Yes, from my reading, they can tell its a different pcm. My opinion though is if I have stock calibrations altered and something goes wrong, its on me.
Old 04-19-2017, 11:03 AM   #18
Corner carver
Same here, pay to play
Old 04-19-2017, 11:12 AM   #19
Adp2017
Adp2017's Avatar
Drives: 2017 RS Turbo
amen!
2017 1LT | RS | 2.0T | M6
331 rwhp , 350 rwtq
ZZP Intercooler | ZZP Catted DP | Magnaflow Catback | Injen CAI | Tuned (BBR) | CNC Honed Turbo (TPC) w 14lb actuator
Adp2017 is offline   Reply With Quote
Old 04-19-2017, 12:41 PM   #20
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Rob and others with a 2017 A8 you will be limited in your tuning ability you could easily do over what i am if you get your TCM done but on 2017s you need to physically send your TCM to HPtuners to unlock it's not remote unlockable at this time.
Old 04-20-2017, 11:07 AM   #21
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
If you brought the car in with a 'back up' computer, they can tell. The part number used for the initial calibration won't match the calibration your car shipped with. You'd have to keep your 'stock' ECU clean. Even that won't save you. If you bring you car in with the rods hanging out of the block, and a clean ECU with no freeze frame data, or emissions readiness monitors set, or diagnostic codes set, they will laugh you out of the dealership along with denying your warranty.
Exactly. Gotta pay to play. They can tell if the ECU wasn't in the car when the problem happened. I gave an extreme example above, but people don't realize that there are other simpler ways of being caught.
ChicagoTommy is offline   Reply With Quote
Old 04-20-2017, 11:12 AM   #22
RobsCountach
Drives: '17 LT 2.0T AUTO
RPM Motorsports sells a tuner pkg for the 2017. 'Seems' they can unlock and alter the tune...
I was planning on swapping the tune from theirs, back to stock, IF it required service - would they know ?
RobsCountach is offline   Reply With Quote
Old 04-20-2017, 11:33 AM   #23
Michigan1LTRS
Blessed ❤️
Yes, GM can see it if they are looking.
Old 04-20-2017, 11:38 AM   #24
Evil-Bee-NH
603 Camaros
RPM and anyone with HPTuners or EFILive can unlock and alter the tune on a 2017. They cannot however just unlock and remote program a TCM on a 2017 so your numbers running an A8 will be limited to about what mine is making. To release that extra power safely you need to tune the TCM which at this point is ridiculously expensive.
Old 04-20-2017, 12:57 PM   #25
RobsCountach
With the A8 TCM, Is it just a matter of shifting early?
Old 04-20-2017, 04:09 PM   #26
Evil-Bee-NH
603 Camaros
GM has put so much torque management in these cars it's insane i thought I'd be good with the ecm tune for my target goal of 5th gen V8 power and i was wrong it's totally doable with bolt-ons but the TCM has an additional layer of torque management opposite the ECM.
Old 04-21-2017, 10:06 AM   #27
ChicagoTommy
Yeah, you really need to get yours out on a track to see what it runs without the TCM being tuned. Have you looked into the possibility of buying a spare TCM?
Old 04-21-2017, 10:11 AM   #28
ChicagoTommy
Yes. Tuning back to stock still changes the flash counter/checksum they are using. If you tune your ECU at all, you are effectively voiding your warranty. That said, if no one ever goes looking into your ECU, you'll be fine. They aren't going to pull an ECU image when repairing a defective power window motor. But the second you have a drivetrain problem, that is going to be on your dime.
Secondly, no tuner is immune presently. They all alter the flash counter/checksum. Even the canned tunes like Diablo/IPF/etc.
