Old 03-09-2017, 10:59 PM   #15
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Yes, 10 quarts, same as the standard SS. The 1LE's engine and cooling package is no different.
I have just over 1,200 miles on mine [yeesh that's it!] and at 941 miles I did my break-in oil change, and almost exactly 10 quarts came out.
Just for FYI, the factory fill on my car was an xW-20, based on my Blackstone UOA results.
Originally Posted by AZ_1LE View Post
What oil is everyone running?
I have 650 miles on my 1LE and just drained and switched to Mobil 1 0W-40 partially because I'm doing a track day on Saturday. The OEM oil looked pretty good, albeit a bit dark for only 650 miles.
After the track day, would you guys recommend switching back to 5w-30 dexos2?
The warranty-friendly answer is: dexos 1 5w-30 for the street, and 5W-40 dexos 2 for the track.
The real answer is; whatever oil gives you a rational viscosity at the operating temperature. With the stock "oil cooler" on the track, you'll want at least 5W-40. With an external Setrab oil cooler and oil temps more in the 230F range, a 5W-30 dexos 1 will end up being perfect.
Old 03-09-2017, 11:00 PM   #16
171LE
Drives: 2017 Camaro 1SS 1LE Nightfall Grey
Originally Posted by JeromeS13 View Post
I can confirm. I changed my oil yesterday. I'm glad I have an 11 quart capacity drain pan...
What do you think of Motul, I have always used Amsoil but it's not on the magical list...
171LE is offline   Reply With Quote
Old 03-10-2017, 10:38 AM   #17
AZ_1LE
Drives: 2019 ZL1 1LE
Thanks. I checked a few stores and couldn't find a single bottle of 5w-40, with or without the dexos2 badge. Manual said 0w-40 and I've used that oil before with good results in my old RS4, so that's what I went with.
I'll be interested to see how the oil temps do at the track this weekend, but also once the real Arizona heat kicks in and ambient gets up into the triple digits.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
