Old 01-18-2017, 07:49 AM   #1
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
How is oil consumption?
With so much focus on catch cans I've started to wonder if these engines consume oil at a faster than "normal" rate. Anyone with observations on this?
Already been through this before with my present car. Before I pull the trigger want to understand if anyone has noticed potential issues. It may be too early to know. Honestly don't know how long this particular engine has been in production.
MAGAUSA is offline   Reply With Quote
Old 01-18-2017, 08:57 AM   #2
SS2017
Drives: 2SS & GT Premium
May want to ask a mod to move this out of the 1LE section...as the engines are the same in all SS's.
My SS has about 5000 miles, it used about 3/4 quart over the first 1000 miles, none since...
I did not do an easy break in by any means either. My car was at the autocross track when it had 60 miles on it. IMO babying the car during "break in" is not the best way to go. I know this is very debated, but that is my opinion as someone who has actually built engines. Machining tolerances these days are fantastic. I have always done this hard type of break in with my modern cars, with great results...
Some good reading here: http://www.mototuneusa.com/break_in_secrets.htm
SS2017 is offline   Reply With Quote
Old 01-18-2017, 09:10 AM   #3
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
I've only got 500 miles on my SS 1LE so far, just checked the oil again...it hasn't used any. Oil level is still like 85% or so up the dip stick...
Old 01-18-2017, 10:11 AM   #4
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
around 1500 miles I was right around 1 quart low. I'll check again before I do my first oil change and let you guys know how it looks.
Old 01-18-2017, 10:14 AM   #5
tx6g1le
tx6g1le's Avatar
Drives: 2017 Camaro 1LE
3000 miles and no sign of consumption (been checking every 500 miles).
tx6g1le is offline   Reply With Quote
Old 01-18-2017, 11:18 AM   #6
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Just checked mine, at about 1000 miles and it's above the fill line, will probably need some if I wait for 1500 to do the first change but I'm probably getting it done sooner.
It is typical for them to use more than normal in the break-in phase.
IG: @NC_M1SS1LE
Old 01-18-2017, 12:03 PM   #7
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
What do you consider the fill line? Below the cross hatching? From what I have read, the cross hatching from bottom to top represents 1 quart.
Old 01-18-2017, 01:04 PM   #8
Iron Oak
Club Motorsports Track Op
Iron Oak's Avatar
Drives: STI, Land Rover and future 1LE
Can someone confirm that the oil capacity is 10 quarts on the 1LE? Due to larger oil coolers etc I would assume?
Iron Oak is offline   Reply With Quote
Old 01-18-2017, 01:14 PM   #9
JeromeS13
Drives: 2017 1SS/1LE
I can confirm. I changed my oil yesterday. I'm glad I have an 11 quart capacity drain pan...
Old 01-18-2017, 01:37 PM   #10
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
hmmmm then maybe mine is a little low, it was about mid-way up the cross hatching. But like I said I'm going to do the break in oil change very soon, and my car isn't getting driven a ton due to the weather.
IG: @NC_M1SS1LE
Old 01-18-2017, 01:51 PM   #11
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
If you're half way up the crosshatching I wouldn't add any oil. The dip stick can be tuff to read. If anything maybe you are like 1/4 quart low. Hard to say...
Thinking I'm gonna change my oil at 1000 miles. 500 seems too short, 1500 too long.
Old 01-18-2017, 02:12 PM   #12
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Yea that sounds about right to me, I will be hitting 1000 by the end of the week, so I may take it by the dealer after C&C on Saturday.
IG: @NC_M1SS1LE
Old 03-09-2017, 08:20 PM   #13
AZ_1LE
Drives: 2019 ZL1 1LE
What oil is everyone running?
I have 650 miles on my 1LE and just drained and switched to Mobil 1 0W-40 partially because I'm doing a track day on Saturday. The OEM oil looked pretty good, albeit a bit dark for only 650 miles.
After the track day, would you guys recommend switching back to 5w-30 dexos2?
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 03-09-2017, 10:58 PM   #14
171LE
Drives: 2017 Camaro 1SS 1LE Nightfall Grey
I lost half a quart in the first 500, nothing since and I am at 3000.
I had the oil changed at 1600 and hadn't checked it in at least 500 before that, so my number may be off a little.
171LE is offline   Reply With Quote
