Old 01-12-2017, 01:50 PM   #15
dpelow07
Drives: ats
why wait for the new turbo by phasetek? there are a bunch of options for bolt on big wheel turbos already
dpelow07 is offline   Reply With Quote
Old 01-12-2017, 02:06 PM   #16
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
The turbo isn't 'by' Phastek. It's a new Misubishi unit.
ChicagoTommy is offline   Reply With Quote
Old 01-12-2017, 03:15 PM   #17
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Originally Posted by ChicagoTommy View Post
Don't mind him, he has no clue about anything mechanical. I believe he is talking about the in tank low pressure fuel pump, which I highly doubt is any different than the low pressure fuel pump in the I4 or V6.
No, the LT1 high pressure fuel pump will not work with the LTG. The only way to get more out of the HPFP is to change the cam lobe that runs the pump. ZZP does offer this on their Stage 2 cams.
I will say this. I know for a fact that a 5th gen ZL1 in tank pump output is more than the rest of the pumps. 5th gen V6 guys that start running out of fuel switch to the in tank ZL1 pump. It does help.
The in tank pump for the 2.0 is the same as the 3.6, but the 6.2 is different. How I don't know, but I would bet that the LT4 pump for the new ZL1 would be worth doing if at some point the 2.0 guys start running out of fuel...
As for the high pressure fuel pump... A lot of GM parts are interchangeable these days, they just don't want you to know it... The 2.0 HPFP is shared with the 2.5 NA engine. But the LGX v6 HPFP is also used on the supercharged Z06 corvette, along with 4.3 v6 engines, 5.3, 6.2 in the silverado and many more. I can't seem to find the 6.2 Camaro HPFP listed... But if the LGX pump is good enough for the Z06, that's pretty surprising they would use the same pumps.
If I ever get to a point to where I need more fuel, I'd buy an LGX HPFP and see if it bolts on... It wouldn't surprise me if it does... But if it doesn't, I'll make it.
Old 01-12-2017, 03:59 PM   #18
ChicagoTommy
I fully agree with you. ZL1 pumps have been known to be an upgrade even on other LSx vehicles. However, that's not the misinformation that Evil Bee was trying to spread. I would hate for someone to waste their hard earned money buying a part that is already in their car. That is what I take issue with.
Old 01-12-2017, 08:01 PM   #19
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Again just not gonna continue with this pointless arguing Tommy. To restate my original post I said using an SS Fuel Pump "Might" work I never said anything about a HPFP and though I am not a mechanical expert I do know that starving an upgraded HPFP is a catastrophe waiting to happen if the stock fuel tank pump cannot get enough fuel to it you can and will cause damage to an engine eventually. I was strictly going from my experience with the 3.6 LLT Engine in the Camaros where people were upgrading fuel pumps in the tank before messing with anything else for that reason. Our cars do run naturally very rich out of the gate so we may only need to upgrade the HPFP but at those higher numbers and without a guinea pig car to see yet nobody knows because saying the 2.0 Camaro is the same as the 2.0 ATS is dumb just like when they said the same thing about the 3.6 LLT that was in both cars thus far the aftermarket between the two has been very kind to us.
