#15 |
Camaro104...
Part numbers? and sources? |
#16 |
![]() Drives: 2016 Camaro V6 2LT RS Fully Loaded Join Date: Sep 2015
Of course all this AFTER I did mine and cut the wires voiding warranty.... Just couldn't wait any longer ugh.
Edit: Cutting wires would void warranty right? But is that jut for the 36,000 miles or lifelong warranty of car?
Borla ATAK w/ Midpipe, VMAX TB, K&N Filter, Subwoofer, Tinted, AFM Disabler, Vitesse Throttle Controller!
ORDERED:08/19/15 DELIVERED:12/09/15 My 2LT Review/Pictures/Mustang Comparison My 2016 Camaro Bose Subwoofer Install 2016 Camaro V6 Stock to Borla Atak Exhaust Sound 2016 Camaro V6 Resonator & X-Pipe Replace with Midpipe & Borla Atak Last edited by NY Andrew; 12-22-2016 at 06:09 PM. |
#17 |
Metra 70-2057 2014 & Up GM Amp Bypass Harness https://www.amazon.com/dp/B012PRQPPY..._Ptfxyb7AYBRM5
This is one of them... Metra 71-2107 Reverse Wiring Harness General Motors OEM Truck/Suv 2015-UP https://www.amazon.com/dp/B01ECPP1YI..._IDfxyb4A52QYS Other.... |
#18 |
You never know how a service tech will interpret modification done to the car. You could do the most elegant and sophisticated upgrade to the audio system, and a tech troubleshooting your trunk release mechanism could say it wasn't working 'cause you messed with the stereo. I always try to do modifications in such a way that they are not obvious. If you have an electrical problem in the trunk area and they see cut wires, they are probably going to jump to conclusions (that aren't necessarily correct).
#19 |
You are so right, I work at a dealership and once they see that all bets are off.
#20 |
![]() Drives: '16 vert 2LT RS NPP Join Date: Jun 2012
Mods do not necessarily imply voided warranty. The issue is that if a problem arises it becomes a "he said she said" thing. Dealer says something you did messed up something else. That could be true or not. If you disagree it will end up in arbitration. If you splice wires at the amp and then your stereo up in the dash breaks, I can see them denying that. Now, if your NPP falls off the car or your transmission fails, most likely warranty will cover as there is no relationship between those parts.
#21 |
So when you guys go in to the dealership, will you be unplugging your whole audio setup? Should I maybe go the route of fixing everything to the way it was and use a harness?
ORDERED:08/19/15 DELIVERED:12/09/15 My 2LT Review/Pictures/Mustang Comparison My 2016 Camaro Bose Subwoofer Install 2016 Camaro V6 Stock to Borla Atak Exhaust Sound 2016 Camaro V6 Resonator & X-Pipe Replace with Midpipe & Borla Atak |
#22 |
Any update on the completed harness?
#23 |
I have a little progress on my installation, all ready to go in only wish the weather was warmer. Here's a few pictures of my setup with the one amp so far....
#24 |
![]() Drives: 2016 Camaro 2SS Join Date: Sep 2015
The image of your completed harness....does that consist 100% of the 2 part #'s you have linked above? the Metra 70-2057 and Metra 71-2107? If so, can you do a write with regards to how you created the connections/pin outs?
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
#25 |
OP, you don't have the Bose system, right? I have the Bose and it seems I'm still missing one harness for the gray connector on top. If anyone has a part number fro that I'm all ears.
#26 |
he listed 2 different amazon links ....did you purchase both? i am hoping for a detailed write up to make one myself...
It would also be nice to know if a plug exists to bypass ANC microphones without cutting the wires
#27 |
Yes, I got both. The short green connector is Metra 71-2107 and the green connector with the long wires is Metra 70-2057. In my case the black connector that comes with Metra 70-2057 does NOT fit anywhere. The 71-2107 harness also comes with a gray connector that does NOT fit anywhere in the Bose system. This is why I'm assuming he has non-Bose.
#28 |
I'm so sorry guys I don't really have time to really get into putting the system together plus it's too cold out side to work on it, don't have a garage. I do have the boss system and again I'm sorry for not being thorough but I will write my installation when I'm done. There is another harness you going to need, i got it from amazon PT2641 that Is the black 8 pin harness.... Hopefully I'll start working on it soon....
