Old 05-15-2016, 03:53 PM   #15
ChefBorOzzy
ChefBorOzzy's Avatar
Drives: 2016 F150
Originally Posted by Riles0303 View Post
Sounds like it but I think he's in manual mode. I let off the throttle and it's stuck until the trans decides to up shift....which is up to ten seconds later. I want your input so I can stop doing something stupid if that's the case.
He's in Drive.
ChefBorOzzy is offline   Reply With Quote
Old 05-15-2016, 03:53 PM   #16
laynlo15
Drives: 2022 Lt1 A10
I've had mine down shift at over 100 mph at the drag strip when I let off right past the traps. So, I just pop mine over into the manual mode and slap it into 8th gear.
Old 05-15-2016, 03:54 PM   #17
Riles0303
Drives: 2016 2ss
Originally Posted by nvrsatisfied View Post
I can only guess that it's in track or sport mode which will hold the gear longer. Also, it would require more than a "blip" to downshift.
Ahhhh.....thank you it's in sport mode and now it makes sense. I apologize for the term "blip".......ex bike racer and it's just burned in my brain.
Riles0303 is offline   Reply With Quote
Old 05-15-2016, 03:54 PM   #18
Joey Rosario
Drives: 2016 SS Camaro 2SS
My SS is doing something like this as well. If I am going 65 and hammer it sticks in the gear that it downshifted too until I switch shifter to manual mode then back to auto. Then it will shift. Basically it is getting stuck in 6th or 7th. I am afraid to take it in after my experience with my second 2015 Escalade LOL.......
Joey Rosario is offline   Reply With Quote
Old 05-15-2016, 03:55 PM   #19
ChefBorOzzy
Drives: 2016 F150
Straight from the manual.
"Performance Shifting
While driving in Sport Mode (V6),
or Sport Mode and Track Mode
(V8), if Tap Shift has not been
activated, the transmission
determines when the vehicle is
being driven in a competitive
manner. The transmission may
remain in a gear longer than it
would in the normal driving mode
based on throttle input and vehicle
lateral acceleration. If there is a
rapid reduction in throttle from a
heavy throttle position at high rpm,
the transmission will maintain the
current gear up to near redline rpm.
While braking, the transmission will
automatically downshift to the next
lower gear keeping engine speed
above approximately 3000 rpm.
If the vehicle is then driven for a
short time at a steady speed, and
without high cornering loads, the
transmission will upshift one gear at
a time, until 8 (Eighth) gear. After
shifting to 8 (Eighth) gear, or coming
to a complete stop, the transmission
will return to normal Sport Mode
shifting."
Old 05-15-2016, 03:56 PM   #20
Riles0303
Drives: 2016 2ss
I think it's figured out....just new to me and I'll work on describing things more accurately for better help. Thanks for your input and help.
Old 05-15-2016, 03:58 PM   #21
Riles0303
Drives: 2016 2ss
shifting."
I should probably read that since it's basically a completely new animal! Thanks again
Old 05-19-2016, 03:41 PM   #22
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
[url=http://goo.gl/Kt1RzU Posted by Riles0303[/url] This has occurred multiple times now....sometimes at over 5 grand......not a fun experience. Can't manually shift it to lower rpm's. Going in Monday for oil pickup check and now I guess a new tcm. Not really happy about this.
Hello Riles0303,
I am sorry to hear you're experiencing this shifting concern with your Camaro and recognize your frustrations. I have taken some time to read over this thread, and see that other forum members have offered some great advice. While I understand that you may have been able to figure everything out, feel free to send us a private message if we can be of any additional assistance.
Kindly,
Julie C
Chevrolet Customer Care
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
Chevrolet Customer Svc is offline   Reply With Quote
Old 05-19-2016, 03:56 PM   #23
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
shifting."
Most helpful Mustang driver ever You should have a private course to teach new Camaro owners how to correctly operate their vehicle.
Thor142 is offline   Reply With Quote
Old 05-19-2016, 04:07 PM   #24
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
It is performance shift mode you can get out of this mode by quickly shifting the shifter to manual mode and back to drive. Or you can let off throttle for 8 seconds and it will return to regular mode.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 05-19-2016, 04:36 PM   #25
E-Ray
Drives: 2016 Camaro 2SS, Nightfall Grey
Pretty neat feature, I like it.
E-Ray is offline   Reply With Quote
Old 05-19-2016, 11:40 PM   #26
DDustiNN
DDustiNN's Avatar
Drives: Cars
Sounds like sport mode. My 2010 SS did that, and my Ford Fusion Titanium does as well. But in regular D mode, it's not nearly as jarring.
DDustiNN is offline   Reply With Quote
Old 05-20-2016, 09:16 AM   #27
gdespaux
Drives: 2016 Hyper Blue Camaro/2LT RS
I had the same 'issue' as well. I understand now that it's by design, but initially was a bit freaked as it doesn't sound very good while this is happening and I didn't know you could toggle to manual and back to force the shift. Good info!
Current:
2016 Hyper Blue A8 2LT RS
Previous:
2010 Victory Red 2LT
I've never had a V8
gdespaux is offline   Reply With Quote
Old 05-22-2016, 09:01 AM   #28
addisonpeterson
Bad Camaro
addisonpeterson's Avatar
Drives: 2013 Camaro 2LT Convertible RS
I actually experienced this when I test drove the car. It was pretty scary I thought I had broke it. We were going down hill at 45mph and the transmission wouldn't up shift and it was banging off the red line until I pushed the throttle a little uphill. I just thought maybe the transmission was trying to figure out what I was doing.
addisonpeterson is offline   Reply With Quote
