Old 05-06-2016, 01:40 PM   #15
crabman
Drives: Sniffin the tree.
HP aint cheap nowadays. A sideline to FI with headers is the headers generally reduce the actual boost a little bit while holding the power up. You can always pully to get the boost back if you want too and realize more power. Lots of choices a guy can make...
crabman is offline   Reply With Quote
Old 05-10-2016, 01:08 PM   #16
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by ender2664 View Post
20hp for a 2k exhaust...doesn't seem like a good deal to me
As technology progresses it is getting harder and harder to find those cheap bolt ons that make power easy.
Keep in mind ARH is 100% high grade stainless and made in the USA.
I think it is a great value.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 05-10-2016, 08:32 PM   #17
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Ted.
True Dat.
I have purchased Stainless Cat-back systems for other cars. Nothing like a True Stainless system front to back.
These were approx. $600-$800 for just a single exhaust.
I can appreciate the amount of material used in the Camaros Dual System.
The price is right.
Old 07-19-2016, 03:58 PM   #18
jimmypop13
Drives: 2016 camaro ss
I'm curious since I have an A8, does anyone know if the tune disables AFM/v4 mode?
Thanks
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 07-20-2016, 05:31 AM   #19
JoeAyalaM
Drives: Audi S6 V8TT, Volvos XC60 & S60R
The included Magnuson tune does not disable it, so I think a custom tune could keep it or not.
JoeAyalaM is offline   Reply With Quote
Old 07-20-2016, 06:37 AM   #20
JANNETTYRACING
Thanks
I disable it in all my custom tunes, I find the car is much more enjoyable to drive and fuel mileage does not suffer around town or in our Hilly North East area on the highway.
Ted.
Old 07-20-2016, 02:04 PM   #21
JaxChris
Were the ARH dyno numbers with or without a tune? I'd actually be a little surprised to see a 5% increase with just exhaust and no intake or tune. The numbers the C7 crowd is seeing from minor bolt-ons are not that high. Wonder why the Camaro would get more return on a similar upgrade -- unless maybe that is where GM restricted to put out a 5hp lower rating?
Old 07-20-2016, 04:11 PM   #22
JANNETTYRACING
The exhaust on the Camaro is pretty bad, maybe that is how they were able to lower the advertised numbers.
They respond very well with headers same with and without a tune just no codes.
Ted.
Old 07-20-2016, 07:47 PM   #23
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
They sound great too. There's nothing like watching some lady in her minivan jump out of her skin when you hit the gas It's like having your high beams auto flash people in front you on the highway...everyone gets out of your way. If you want it quiet and have the NPP, just grab one of those Forza controllers and map it to your homelink buttons. It's been working great for me and you get the best of both worlds.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 07-26-2016, 04:27 PM   #24
Razzaa
Razzaa's Avatar
I am about to pull the trigger on the same set up!! Have you launched it from a dig yet? How did the runflats hold up? I'm trying to figure out if I will need better tires. Thanks!!
Razzaa is offline   Reply With Quote
Old 07-27-2016, 06:40 AM   #25
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Yes but I haven't pounded on it from a standstill much. The very first time I tried competitive mode I got 3.5 seconds for my 0-60 time and I don't even consider myself to be anything special when it comes to driving a stick. The run flats are much better than I expected, but if you lay on it in any gear below 3rd you're going to get a little squirrely in back, regardless of how fast you're going and the conditions. The stock tires are not nearly as bad as I thought they'd be, but they're still relatively new.
I just got new wheels and tires, which are very sticky. I would highly recommend making sure you're in competitive mode if you do launch, since it turns off TC (or just turn off TC). It could save you from causing damage. I tried it twice so far with my new set up. The first time I was in competitive mode and the tires barely spun. It took off like a rocket, but I was playing it cautious and didn't drop the clutch hard enough to trigger the 0-60 timer. I wish it would've worked because it was like being shot through a cannon lol.
The second time I was at a light turning onto a 4 lane road with a speed limit of 50. The road was really well paved and I had a clear straight shot. When the light changed I dropped the clutch a little more aggressively and started to feel some wheel hop, so I let off right away. With larger, stickier tires you've got to be careful. I can count the number of times I've taken off hard on one hand, but I think I'm still going to look into upgrading my rear-end soon.
Old 09-15-2016, 07:22 AM   #26
JANNETTYRACING
Bump for the new guys, any questions please post them here be glad to answer.
Ted.
Old 09-15-2016, 02:04 PM   #27
Daves1SS
Daves1SS's Avatar
Drives: 2016 Camaro 1SS
Out of curiosity on this setup, was the crushed exhaust just prior to the NPP muffler left as-is from the factory? I know on a stock car replacing it does nothing for HP, but didn't know if it could provide any gains whatsoever on a boosted setup. Maybe so, maybe not.
2016 Nightfall Gray Metallic 1SS 6MT, Edelbrock E-force supercharged, Killer Chiller with 3-way bypass, catch can ***FOR SALE, MESSAGE ME IF INTERESTED***
Previous:
'12 Mustang GT 6MT (12.47 @ 115.88)
'09 G8 GT (11.86 @ 120.47)
'05 GTO 6MT (slow, lol)
'01 Grand Prix GTP converted to turbo, high 11's
Daves1SS is offline   Reply With Quote
Old 09-15-2016, 03:34 PM   #28
AGP Turbo
Drives: All things Turbocharged
Uncle Ted!
You're killing me with the overlay but different scaling left side HP to right side TQ. I think that makes it look like the power comes on slower than it actually does. Funny that now the 1.7L guys are going to call 2.3L PD laggy. haha.
AGP Turbo is offline   Reply With Quote
