Old 02-24-2016, 06:10 PM   #15
The1DoubleN
Drives: Blown up '16 SS
Originally Posted by MikeyCamaro View Post
A8: The 8L90 has a torque capacity of 738 pound-feet (1000 Nm).
Source: http://gmauthority.com/blog/gm/gm-transmissions/m5u/
M6: TR6060 torque limit: 420 lb/ft
Source: http://www.chevrolet.com/performance...ns/tr6060.html
Mike
So the MT's in our cars are not equipped to even handle the stock power levels? WTF?
The1DoubleN is offline   Reply With Quote
Old 02-24-2016, 06:15 PM   #16
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
Mike
Says the Challenger guy? I know it can handle alot more. lol The 5th gens easily held any supercharger.
This is off of Tremec's website:
http://www.tremec.com/anexos/TREMEC_TR-6060.pdf
So anywhere between 430-650 ft lbs input torque as a reference.
The Challengers, vipers, 5th gen camaros have already proven this transmission is way more capable than 420 ft lbs.
drivingagain is offline   Reply With Quote
Old 02-24-2016, 06:15 PM   #17
parish8
Drives: 17 SS a8
Originally Posted by The Idiocracy View Post
Something tells me you are the same Parish from PT.net? You looking for the next project?
Yes. Thinking twins on a mostly stock car might be into the 9's. Seems like a lot of bang for the buck and they are so nice looking.
Old 02-24-2016, 06:19 PM   #18
The1DoubleN
Looks like there's more to the story.....
List of gear ratios:
http://www.hotrod.com/features/1505-...the-sixth-gen/
Tremec's list of available gear ratio setups and their respective published torque limit guidelines
It looks like the 6MT we have falls somewhere between gearing B and C of the above (gears 1-4 type C, gears 5-6 type B), which show limits (or guidelines if you will) of 560lb-ft (gears 1-4) and 500lb-ft (gears 5-6) respectively for the TR-6060.
Old 02-24-2016, 06:23 PM   #19
The1DoubleN
There's also this for when your tranny ultimately fails....rebuild it stronger:
http://www.tickperformance.com/tr-60...ld-packages-7/
Old 02-24-2016, 06:41 PM   #20
The Idiocracy
Drives: 2016 Black SS
I've had the same thought myself. 14-15 psi will be ~800 at the wheels. It's really tempting.
I think that LT4 engines have additional fuel pumps in the tank already. I'm not sure on that. Being direct inject, I'm not sure if it's similar to standard injectors, but I have heard that in stock trim we are near capacity of the stock pieces. Same as the LS based motors in stock trim. Torque limits are the same, only engineered to handle stock power. Some will be freaks, others fail early.
On the rear, they do have an LSD, not electronic though. That's reserved for special camaro a and vettes. I can say the traction control is functional and needed in this thing. The other day a downshifted into 4th at around 70 and felt it start to get squirrley, and the icon was flashing on the dash, telling me I lit the tires. I was surprised to say the least.
I haven't been on PT in a while, do you still have that blue truck?
The Idiocracy is offline   Reply With Quote
Old 02-24-2016, 07:37 PM   #21
MikeyCamaro
Drives: 2015 Challenger SRT
Actually, says Chevrolet. That's why I posted the source. :p
Well, since the Camaro's gear ratios don't match anything listed, maybe it's OK to "interpolate" between columns and The1DoubleN is right: it's somewhere between 500 and 560 lb/ft.
But we all know, you can often exceed official ratings by a substantial amount anyway.
Mike
MikeyCamaro is offline   Reply With Quote
Old 02-25-2016, 03:13 PM   #22
Fraxum
Fraxum's Avatar
Originally Posted by lcarney1977 View Post
Does anyone know how much RWHP the new 16ss can handle safely without upgrading the trans? Looking to do a procharger and it should get to 580-620RWHP but wanna make sure that's safe I have the M6 2SS..my 2010 Camaro had 615RWHP and with 19k miles and now the trans went that's why I'm asking thx....
From what I read the new 8 speed auto can handle big power. So can the M6 if you can cough up the $8K for clutch and diff upgrades. I was pushing 625-650RWHP in my last 1LE. I drag race often. Everything broke but the transmission. Even though the 1LE had a stronger M6 than the standard SS your transmission should be fine @ 625 RWHP. But be prepared to spend more if you actually use that power.
On both CA6es you will need to beef up the suspension too.
