Old 08-17-2017, 10:42 AM   #225
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Do I like that I get windshield condensation and a slightly ill fitting headliner? Absolutely NOT, and it shouldn't have that for $40+K. But, I didn't buy this car for Mercedes fit and finish. When I wind it out, or slam it into a corner, it's like, "What headliner/fogging"?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 08-17-2017, 11:22 PM   #226
TenSeven
Drives: 2016 Camaro SS
Originally Posted by bryguycbr View Post
Somebody should try this:
I went to Hobby Lobby and looked at all the stuff they have, trying to build something on the fly. Get some heavy stock paper, they have various sizes and colors, choose a color close to dash color, find some double stick tape, they have various types. Cut a template of the vent using scrape paper, to get size, cover the red security light also. The vent has a small boarder around the whole vent assy. Use double stick tape around edge of cut paper, cut hole for security light, double stick around edge. The double stick tape should be tacky enough to seal edge and stop cold air from drifting onto windshield. My vent doesn't feel like a high force of cold air, but some cold air does exit. I haven't cut, built, this yet, but in theory, it might work.
Maybee Chevrolet Customer Service lurking around on this forum will see this, and have GM design engineers, build something like this for a fix/repair.
When I read it in another thread, I did almost exactly this using vinyl wall base I got from Home Depot for a few bucks.
Used a piece of cardboard to make a template, transferred the shape to the vinyl, cut it out with a scissors. The black vinyl blends well with the dash and the lip molded into the vinyl keeps it in place.
I was all done in 20 minutes for $5 and it works great!
TenSeven is offline   Reply With Quote
Old 08-17-2017, 11:30 PM   #227
KirkH
Respectfully, the point is, we shouldn't have to lay a piece of vinyl in the windshield of a 2016-17 vehicle.
Old 08-18-2017, 01:12 AM   #228
TenSeven
Oh, I definitely agree, in no way was I trying to justify Chevy's f-up with our cars' HVAC system. How something like that wasn't caught in testing is unacceptable. Someone in testing got lazy.
Just wanted to say there is a quick/easy/cheap workaround to the issue. No, it's certainly not ideal, but it works.
Old 08-18-2017, 04:43 PM   #229
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
If I see it starting to fog up I hit the defroster on high heat for a few minutes and it clears right up. I crack the windows so I get fresh air circulating.
dpevans is online now   Reply With Quote
Old 08-18-2017, 06:06 PM   #230
JFM-jr
JFM-jr's Avatar
When its 92 degrees out thats the last thing im doing.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 08-18-2017, 11:17 PM   #231
Sub
Sub's Avatar
Drives: 2017 ZL1
Never had this issue on my 16 s s. Just got a zl1 and started noticing it today with the a/c on, although, it has been raining a lot and it very humid. My condensation is on the outside though, not inside. Wipers cleans it away..
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 08-27-2017, 05:44 PM   #232
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Had the repair work done (removing foam blocks). And I figured out that it only fogs up (and much less than it did before)if I go with the following settings:
- Temp lower than 71
- Fan higher than 4 lights
If I go more extreme than that, then I get the 2 spots over the vent and they're each about 2.5" wide
classicrockr is offline   Reply With Quote
Old 08-27-2017, 07:41 PM   #233
Wheel Team 6
Wheel Team 6's Avatar
Windshield fogging
Sounds like you have the same results bad me. An improvement but not a complete fix.
Wheel Team 6 is offline   Reply With Quote
Old 08-28-2017, 12:53 PM   #234
JaxChris
Foam block removal?
Old 08-28-2017, 02:18 PM   #235
TheHulk2SS
TheHulk2SS's Avatar
Drives: 2017 Krypton Green 2SS Converible
Tomorrow is the Day
Well it looks like I'm going tomorrow morning to Lou Bachrodt Chevrolet in Ft. Lauderdale to find out their recommendation on the condensation issue. I got all the "ammo" from the threads on this site. I hate the thought of removing anything from the car but as a "daily driver" the condensation issue really becomes a pain and it's somewhat embarrassing especially with my buddies that happen to drive Mustangs. I'll update my post later.
TheHulk2SS is offline   Reply With Quote
Old 10-05-2017, 10:37 AM   #236
Ryan4290
Ryan4290's Avatar
Drives: 2017 Camaro 2SS
Originally Posted by Bradl1982 View Post
I've had my car for about 2 weeks and have had this issue every morning here in the St. Louis area. I have experimented with different settings on the A/C and so far nothing works. Below is a list of cars I have owned that never had this issue, it is not normal.
1992 Plymouth Sundance
1995 VW Jetta
2000 Camaro SS
2001 VW Golf
2008 Corvette
2009 Corvette
2012 Ford Focus
2012 GMC Acadia
2013 Cadillac SRX
2014 Ford Focus
2015 Jeep Cherokee
Here is a list of vehicles I have owned that have had this problem:
2017 Camaro SS
Yep, i'm in STL and it has been doing it to my 2017 2SS also!
Ryan4290 is offline   Reply With Quote
Old 03-17-2018, 09:10 AM   #237
Nisfero
Nisfero's Avatar
Drives: 2017 Camaro 2SS Hyper Blue
I had the repair done and I can tell you it did not work. Back at the dealership for another go... fml.
Nisfero is offline   Reply With Quote
Old 06-23-2019, 11:13 PM   #238
B4tmbl
Drives: Chevrolet Camaro 2SS Gen 6
I see this is an old thread but headed In with my 17 on wed. Also, anyone know anywhere you can lookup service bulletins by Vin? I have had several fixed the last 2 weeks and want to get them all do t this time before warranty expires.
B4tmbl is offline   Reply With Quote
