#169 |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
Oh yes I see it now lol! What a bizarre design. One side clamps and one side has a flange...
![]() Thanks brosof.
2018 1SS 1LE
#170 |
![]() Drives: 2019 Camaro ZL1 Join Date: Apr 2017
Sorry... a lot of info in here. Does the Borla also delete the AFMs and if so, does that through a code?
#171 | |
![]() Drives: 2018 1SS 1LE Join Date: Aug 2017
Borla part numbers 60609 and 60610 are for the automatic transmission vehicles. They have the AFM. |
#172 |
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
Does anyone in vegas know any shops that would do a secondary cat delete? No one in my city, lake havasu az, will touch it and that's the nearest big city to me
#173 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
DynoSteve at RDP can get you the Borla for $314 (or less) and the clamps will run you $50. If necessary you can always put the stock cats back and re-use the same clamps (1176) to return to stock configuration. Jack that bad boy up and have some fun! No one will be the wiser and your car will sound amazing! |
#174 |
Yah, no luck on any shops. I didn't know that part existed, that's definitely my answer, thankyou sir!
#175 |
You won't regret it. Here's RDP's info-https://www.rdpstore.com/p-12059-camaro-ss-2016-2018-cat-delete-pipe-275-60663.aspx
Use their current Promo Code and save 10%- md10d. |
#176 |
Call Steve by phone. He is nice to talk to. He gives forum members here a little better discount. That is who I got my system from.
#177 |
![]() Drives: 2017 1SS 1LE Silver Ice Metallic Join Date: Jun 2016
#178 | |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
#179 |
![]() Drives: 2018 ZL1 1LE - HBM, PDR Join Date: Jun 2017
60663 is just a secondary cat delete for the SS (2.75"). 60626 is also just a secondary cat delete for the ZL1 (3").
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
#180 |
BL1ZZRD
#181 | |
Thank you sir for following through and making good on your statement! |
#182 |
BL1ZZRD
I crawled under the car yesterday to look at what it would take to install the 60663 and I'm wondering if the sleeve clamps will work. There isn't much pipe between the last bend and the brace that's welded between the stock pipes for the clamp to fit. After the welded brace there's OE dents for clearance so that wouldn't work. Has anyone done this install?
