Old 04-19-2017, 11:02 PM   #1
joeyp85
joeyp85's Avatar
Drives: 2016 2SS MRC,NPP, A8 hyper blue
Exclamation SECONDARY CAT DELETE QUESTIONS
So I've decided to get my secondary cats deleted and I found a video on YouTube of what I think and hope it will sound like. So if I delete the secondary cats on my car, will I experience drone or anything else unusual? I'd like to hear some input that would be greatly appreciated!
https://m.youtube.com/watch?v=fNhhWql9Nv4
joeyp85 is offline   Reply With Quote
Old 04-20-2017, 11:04 AM   #2
joeyp85
joeyp85's Avatar
Originally Posted by CreativeDawn View Post
Drone? No! I have my secondary's deleted and I noticed a louder Wide Open Throttle by about 15/20%! It sounds bolder without the secondary's to be honest! Driving in Stealth is about the same for me however the rattle was a little worst lol.
Joey...Check this video out too! I've seen the one you posted months ago and the beautiful Dog to go with it. This is Matt's video and it's an outstanding mic to go along with the video for the full effect....If you want a bigger positive effect, wear earphones and listen so you pick up all the surrounding noise/frequencies!
1 MINUTE AND 7 SECONDS INTO THE VIDEO ....Drive by
On my part however, I'm dealing with a NEW issue that you might of come across but that's a whole other story. :(
What's the issue you're dealing with? Does it have to do with deleting the secondary cat?
Old 04-20-2017, 03:37 PM   #3
gdgraph
gdgraph's Avatar
Drone will depend on the mufflers you go with, if you are keeping the stock NPP and just doing secondary cat delete it won't change drone, you will just get a little bit more volume out of it and what people describe as a little more of a raspy exhaust note.
I have all of my cats but went aftermarket with the Borla S Type with Mid Pipes (that go up to a few inches behind the secondary cats) and when I hear the same set up with the secondary cat delete and it's only about 15% louder on WOT and a little bit raspier in sound.
gdgraph is offline   Reply With Quote
Old 04-20-2017, 10:09 PM   #4
Teem0s42
Teem0s42's Avatar
Drives: 2017 2SS Camaro
No Drone. Nothing unusual. Same sound as stock just maybe 10-20% louder
Heres a clip of my car after I took out my rear cats. everything else is stock!
https://www.instagram.com/p/BLrn01TgEuw/
Teem0s42 is offline   Reply With Quote
Old 04-21-2017, 12:11 AM   #5
joeyp85
joeyp85's Avatar
Now I'm debating if I should get rid of the muffler as well but I'm probably going to stick with the secondary cat delete for now but I know I'll be happy with it! I'll post a video of it after it's finished.
Old 04-21-2017, 06:26 AM   #6
gdgraph
gdgraph's Avatar
It just depends on what type of sound you are trying to get, if you delete the secondarys and the muffler latter, you'll have a very loud, raw, and raspy sounding exhaust. I went with after market because I needed to be able to turn the loud on and off.
Old 04-23-2017, 09:51 PM   #7
White LT1
Drives: 2017 2SS
I wonder if there is a loss in power if secondary cats get deleted...
White LT1 is offline   Reply With Quote
Old 04-23-2017, 10:26 PM   #8
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Why would there be a loss? They are only there to pass CA emissions.
Old 04-24-2017, 07:04 AM   #9
gdgraph
gdgraph's Avatar
If you increase exhaust diameter without a tune, you can get a loss of low end torque because there's not enough back pressure, but I highly doubt any significant/noticeable loss with a secondary cat delete. Most people do the delete purely for the added sound.
You'd probably see low end power losses if you went to something like 2" headers with a full 3" exhaust and no tune, but not for something like a secondary cat delete.
Old 04-24-2017, 08:17 AM   #10
SuperSound
SuperSound's Avatar
Right, but we are talking about a section of pipe less than a foot long. Now if it was like your example that's another story.
Old 04-24-2017, 09:02 AM   #11
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
Why does the myth of back pressure keep on living? You do not want back pressure... not even a little.
EFI Tuning is offline   Reply With Quote
Old 04-24-2017, 07:27 PM   #12
DD goat
DD goat's Avatar
Drives: 2017 Hyper Blue Camaro 2SS
back pressure is good....in a 2 stroke dirt bike!!
DD goat is offline   Reply With Quote
Old 04-25-2017, 09:34 AM   #13
tireslayer0331
tireslayer0331's Avatar
Drives: 2016 2SS
Can anyone attest to how much louder it is from inside the car? I plan to cut mine out in the next week or two. My blowoff valve is louder than my exhaust from inside the car (sounds like driving through a puddle) when driving below 20mph and I want to hear more exhaust and less air whooshing around. I plan to do primary deletes too next month so hopefully both will take it to the volume I want inside the car!
2016 Camaro SS- , D1SC, 4.38" pulley, LT4 HPFP
tireslayer0331 is offline   Reply With Quote
Old 04-25-2017, 10:26 AM   #14
tireslayer0331
Drives: 2016 2SS
I'd say it's not louder INSIDE the cabin but the general exhaust note is louder outside! That's a good thing...right?
The ONLY negative I noticed was a slightly (and I mean very slight) increase in the Stealth NPP Valve Rattle after the cats were removed but other then that everything was well worth the money to do so.
I can't say if the WOT was louder because when I had them removed I still didn't properly break-in my Engine! However it sounds great at WOT now. :-)
Awesome, thanks. I'm excited to try it out. I think the only time I will use stealth mode is if I run into a police officer to make me a bit less conspicuous so a slight rattle wont bother me.
