Old 03-12-2025, 12:27 AM   #16045
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
So 5 years ago when I got my new 2020 2SS and installed the GMP CAI, I put the CARB sticker (cuz I live in Kommifornia) on the hood where when I was growing up in the 70's and 80's most of the engine stickers were... Shortly after doing that, I had a "WTF" moment and realized I should have put it on the back of the CAI itself... Well, too late, peeling off the sticker would remove a good amount of the adhesive and it would never stick correctly... Which a peeling sticker is not good for my OCD...
Well, I was finally able to find a replacement sticker (SEE HERE if you need one) and today put it where it should have originally been 5 years ago!
BEFORE:
AFTER:
It's the little things that make a difference!
$14.07 WELL SPENT!!!
Old 03-12-2025, 12:17 PM   #16046
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
Originally Posted by S.Macias View Post
Just this pair from Amazon. Held up pretty strong so far. Need two sets because of how they’re threaded.
https://a.co/d/aK0yKzb
Great, thank you!
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 03-12-2025, 01:00 PM   #16047
willzilla
D3RPZILLA
willzilla's Avatar
Finally finished up with installing the front adjustable sway bar and end links from BMR... shortened the front end links a pretty decent amount to give me a good amount of clearance with the stiffest setting and also moved the bushings as far back as it would allow to give me good clearance between the sway bar and the front crash bar.
A few photos:
And I did just receive the BMR billet mounts and Delrin bushings (insanely overpriced, lol) and swapped them in:
Sorry for the lengthy post.. thanks for all whom helped!
Old 03-12-2025, 01:09 PM   #16048
beowulf556
Drives: Camaro SS 1LE M6
New plug wires. That one by the dipstick was a PITA.
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
Old 03-12-2025, 01:19 PM   #16049
clg82
Drives: 2020 Camaro ZL1
A few photos:
Are those suspension components known for having clearance issues?
Old 03-12-2025, 01:40 PM   #16050
willzilla
D3RPZILLA
willzilla's Avatar
Not that I'm aware of.. Only had issue with running the end links at OEM length and slotting into the stiffest sway bar setting. I emailed BMR and they told me, "If you can adjust the endlink to clear that is fine. The zl1’s have some differences from a ss that cause that." and, "No that is fine just make sure the sway bar does not hit anything else in its range of motion."
So, I just shortened the end links and no more clearance issues.
Old 03-13-2025, 06:56 AM   #16051
clg82
thanks for your response dude, watched your video last night....good info.....you ever come up to the Fort Worth area let's meet up for a cruise and a couple of brewskis!
Old 03-13-2025, 07:37 AM   #16052
I upgraded my phone to a (used) Samsung S23 that finally came within my hard budget ($199) after discounts, and guess what, IT FITS PERFECTLY on the wireless charging pad after trimming the long edge end caps, which I already did years ago.
Yes, we all know GM effed up with this constrained design, but where there is a will, there is a way. If one wants, they can wirelessly charge a reasonably modern phone and use wireless Android Auto with 6th gen Camaros, even pre-refresh ones.
Old 03-13-2025, 12:33 PM   #16053
willzilla
D3RPZILLA
willzilla's Avatar
No problem and thank you! Sounds like a plan! I just need to get my car back on the street finally, haha!
Old 03-13-2025, 05:07 PM   #16054
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
Upgraded to Alcantara on the steering wheel, dash, shifter, knee pads and arm rest. Much nicer... should've been like this from the factory. Got all ZL1 stuff so it has red stitching to match the rest of the car.
Bad Anvil Garage is offline   Reply With Quote
Old 03-13-2025, 05:58 PM   #16055
Whoomba
I cut off the tabs (shows on upper left of your pic) and my iPhone 14 Pro fits.
Old 03-13-2025, 07:19 PM   #16056
willzilla
D3RPZILLA
willzilla's Avatar
Nice! I've been learning Autodesk Fusion and doing a lot of 3d printing lately.. I wonder if I can model something up to hold larger phones and still look good... hmmm.
Not a pro by any means and still learning a lot as I go but it's fun to find a problem and then try to figure it out. Just made this to mount an Arlo 4k camera and solar panel to my house, lol..
Old 03-14-2025, 02:12 PM   #16057
Camby
Camby's Avatar
Drives: 2023/2SS/1LE/RadiantRed/A10
Got my ACS skirts.
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
Camby is offline   Reply With Quote
Old 03-14-2025, 03:15 PM   #16058
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Camby View Post
Got my ACS skirts.
Looking good!
