Old 09-14-2021, 10:17 AM   #1513
Sumbata
Drives: Zl1 1LE
2018 ZL1 1LE
Sumbata
Njmp lighting
1:11.5
Hoosiers
Intake
Exhaust
Safety
Sumbata is offline   Reply With Quote
Old 09-14-2021, 11:23 AM   #1514
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Originally Posted by Sumbata View Post
2018 ZL1 1LE
Sumbata
Njmp lighting
1:11.5
Hoosiers
Intake
Exhaust
Safety
Please use the format on the first page and see the first post for requirements. A lot of time goes into keeping this thread updated, please follow the format.
Updated times!
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 09-14-2021, 01:05 PM   #1515
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
Originally Posted by FollowMyLine View Post
Times have been updated, however 5.M0NSTER, could you please update your post with the format from post 1 so we can see what kind of tires you were running, any mods, etc? I gathered from your post that it was on 9/13/21 and a 2018 SS 1LE, but not sure if you have any mods.
Sorry about that and tank you for updating. In the correct format:
Track (which config if applicable) = Gingerman Raceway
Elapsed Time = 1:42.43
Year / Model / Trim / Transmission = 2018 1SS 1LE 6MT
Date = 9/13/2021
Tires = OE SC3
Mods = Hawk DTC60, Castrol SRF fluid
5.M0NSTER is offline   Reply With Quote
Old 09-14-2021, 02:51 PM   #1516
FollowMyLine
Driver for Hire
All good! Updated.
Luan Zeqollari
YouTube Channel
Old 09-14-2021, 07:27 PM   #1517
Roostie
all it takes is cash
Roostie's Avatar
Drives: 2018 LS V6 1LE; 2000 BMW 540i 6MT
Track (which config if applicable) = Willow Springs International - Big Willow - Rosamond, CA
Elapsed Time (please include times to the hundredth if possible) = 1:38.198
https://www.speedventures.com/Result...id=-1999998553 (listed as SuperChicken)
Year / Model / Trim = 2018 LS V6 1LE
Date = 9/11/2021
Tires = 275/45/18 Bridgestone S007A
Mods = 18x10 square Apex FL-5 wheels, Vorshlag camber plates
Hot day at Big Willow, temps got up to low 100s. It was about 90 when I got my quickest lap. I drove the track better as I learned more about it in each session, but my car could not go faster as the temps climbed. Saw peak oil temp of 279 (!!) a couple times and slowed down.
I don't recommend the Bridgestone S007A as a tire to set a quick lap time. They are a fine street performance tire, but don't come close to the grip of current 200TW tires.
I'd like to get back to Big Willow this fall on some better tires and see what I can do.
Roostie is offline   Reply With Quote
Old 09-15-2021, 11:12 AM   #1518
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
Date = 9/11/2021
im doing fontana 10/3 big course and trying to get to chuckwalla again in novemeber if your down? last event for super gt cup is in decemember in buttonwillow but i know thats a mission for you!
Old 09-16-2021, 08:09 PM   #1519
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
**NEW PB (to date...)
Track = Watkins Glen (Full)
Elapsed Time= 2:01.73
Camaro Model = 2016 SS (2/Vert)
Date= 9/13/21
Tires= Pirelli DH (18" 305/325)
Mods= Lowered, FE4 Sways, Brake cooling ducts, UDP, CAI, Ported 95 TB and MSD IM, E85, Headers, High Flow w/ secondary cat, crush pipe, and AFM valves deleted, some weight reduction, Track Alignment w/camber plates, SRF brake fluid, Hawk 70's...
**Broke/sheared off top of right front shock @ camber plate bearing the first morning practice session on the TT-day (day-2/ 9/14).
driven2exceSS is offline   Reply With Quote
Old 09-17-2021, 08:10 AM   #1520
Ckeels724
Ckeels724's Avatar
Drives: 19 riverside blue metallic ss1le
Date= 9/13/21
Great driving!! That's crazy fast at wg
Ckeels724 is offline   Reply With Quote
Old 09-17-2021, 10:23 AM   #1521
kropscamaro16
Date= 9/13/21
jesus thats not good what camber plates/springs? stock struts? is the car ok?
Old 09-17-2021, 07:17 PM   #1522
driven2exceSS
Thanks!!, I really appreciate the recognition
Vorshlag, BMR, OEM Mag-ride. Yes, so far anyways.
What you see in the Pic is the damage. I actually drove it a total of 3-4 more laps (causing more "damage"). The first couple to see what speed I could maintain to not be caught in the TT. Then 1-out lap, and 1-timed lap in the TT. I wanted the points to maintain the class championship
Old 09-19-2021, 07:23 PM   #1523
twinschief
Drives: 2020 Camaro 1SS 1LE
Track = Putnam Park
Elapsed Time = 1:18.27 https://www.facebook.com/tyler.winsc...58999129645995
Model = 2020 SS 1LE
Date = 09/19/2021
Tires = OE SC3s
Mods = Track Alignment, Castrol SRF, SPL rear toe arms, BMR rear cradle lock out, SS track deflectors, and Soler Performance 91mm ported throttle body
twinschief is offline   Reply With Quote
Old 09-20-2021, 04:54 PM   #1524
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
New TRACK DIRECTION Eagles Canyon Raceway
All good! Updated.
Well Eagles Canyon Raceway is now running some of their events in the CLOCKWISE direction which is SLOWER than the CCW direction by probably 2-4 seconds due to decreasing radius turns when going in that direction. Anyway, On 9/19 I ran a 2.08
Eagles Canyon Raceway - 2.7 CW Config - Decatur, TX
1. 2.08.217 SR71BB in 2019 Camaro SS SG3 Suspension, Camber Plates, SPL Toe Arms, APEX EC7 18 x 11 ET27 wheels with Michelin Slicks 30 65 18, DTC70 and DTC60 pads with ZL1 brakes and GOODRIDGE stainless steel lines, Wilwood EXP 600 brake fluid, -3.1 degrees FRONT camber and -2.4 degrees REAR camber Close to ZERO Toe out on Front and Rear
Time documented by by RACE HERO on 9/19/21
https://racehero.io/events/txr-scca-...743488?ref=app
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 09-21-2021, 11:07 AM   #1525
chrisnharris
Drives: 2017 Camaro ZL1
Track = PITT Race (full course)
Model = 2017 ZL1
Elapsed Time = 1:59:05
Date = 09/20/2021
Tires = OEM GY SC3
Mods = OEM track alignment
chrisnharris is offline   Reply With Quote
Old 09-21-2021, 11:24 AM   #1526
Beescuz
Beescuz's Avatar
Drives: 2021 ZL1 1LE
First time ever to Pitt Race
Track = Pitt Race (full course)
Model = 2021 ZLE
Elapsed Time = 1:57.83
Date = 9/18/21
Tires = OEM GY SC3R
Mods = Stock
Beescuz is offline   Reply With Quote
